Posts: 472 |
i have just recently purchased the 9006 headlamps for my car, only to discover that they do not fit, i think i may have read a while ago how to modify them to make the lights fit, however the search function does not appear to be working at this time, any suggestions on how to modify them to make them fit?
thank you
96 gl sport, atx, rip at 95k
FDNY 343 remember 9/11
Posts: 3,064 |
The 9006s are designed for the hight beams correct? But you want them for your lows? If they are they have a tab on inner side of the connecter that you need to cut out with a knife or something like a dremel, which would take less time. Anyhow, be glad you got the 9006s. Most people here buy those, mod them like I said and install them in the lows housing. You just gained a little more wattage.
Posts: 4,220 |
Personally I found it a lot easier to cut away the plastic on the connecting end on the car. Much softer and easier to get to. But it's probably better to cut away plastic on something that's disposable like a bulb, not on the car itself.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 1,444 |
Hmm, maybe it's different from pre98 and post98 because my manual for my 2000 Stique says to use 9006 for the low beam and when I did get the Silverstar 9006's, they snapped right in perfectly.
Posts: 3,115 |
Has anyone ever had a problem with the clear headlight cover getting cloudy? Can you replace them or do you have to replace the entire headlight assembly?
"Eagles may soar high, but weasels don't get sucked into jet engines."
Posts: 1,016 |
Just put in the SilverStars in my '00 CSVT. I used 9005s. The way mine was set up was; 9006 for the lows, and 9005s for the highbeams. I took a Dremel to the plastic tabs on the bulbs. They clipped right in, and are working great. They make a HUGE difference despite what anyone tells you. Maybe check to be sure you are replacing the lowbeams not the highs... G/L
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 3,064 |
I guess I had it wrong, 9005s must be designed for the highs but can be modded to fit the lows. Sorry for the mess up.
Posts: 472 |
i am retarded, i bought these for the high beams, is there any way to make them fit in the high beam slot, they fit in the wire harness but wont click in to the slot
help thanks
Posts: 851 |
Originally posted by TexasRealtor: Has anyone ever had a problem with the clear headlight cover getting cloudy? Can you replace them or do you have to replace the entire headlight assembly?
Try Meguiar's PlastX Clear Plastic Cleaner & Polish. My brother used it on his headlights and it worked great.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by brianl703: Originally posted by TexasRealtor: Has anyone ever had a problem with the clear headlight cover getting cloudy? Can you replace them or do you have to replace the entire headlight assembly?
Still haven't been able to find it.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
