the fuse box you are looking for is on the driver's side, under the dash.. if you look just above the dead-pedal (plastic pedal shaped liner on the carpet), there will be a box (mine is black) pull lever, and it swings downwards, hinged in the back..
As for the computer, make sure you have your internet security settings set to a level that will allow cookies. Tools/Options/Privacy... slider bar moves to allow more or less things..
Ray
