Posts: 281 |
I'm glad u got your car running better. What kind of misfiring did u have, and did it trip the check engine light? I have a similar problem. When my check engine light went on I got a "random/multiple misfire" code.
I reset the code and it hasn't returned, but the car is not idling smoothly, it still misfires slightly at idle and low rpms.
Did u test your coil pack at all to determine if it was bad first? Mine checked out with the ohm meter, but not sure if that means it's fine. I'm hoping your situation was similar to mine, I might just try a new coil pack like you did.
Thanks for any info.. I also PM'd you
96 Contour GL 2.0L MTX with Early SE 7 spoke wheels, SE sideskirts, Koni Sport Kit
70 Mustang Sportsroof with mild 351W and '01 Mustang GT wheels
Posts: 21,653 |
I got a bad misfire with the CEL last week and have ordered a MSD coil. I'll let you know how it goes,,, my engine also doesn't idle great.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: I got a bad misfire with the CEL last week and have ordered a MSD coil. I'll let you know how it goes,,, my engine also doesn't idle great.
It is too fast!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 205 |
I have a used accel pack ill let go for 20 + shipping. PM me.
01 Focus MTX
JRSC, 2.6 pully, and so on.......
Posts: 21,653 |
Originally posted by LoCoZ: Originally posted by Kremithefrog: I got a bad misfire with the CEL last week and have ordered a MSD coil. I'll let you know how it goes,,, my engine also doesn't idle great.
It is too fast!
I think you're right. It's installed, don't really no if it'll make any difference or not.... My engine under light push on the accelerator pedal stumbles. I am convinced this a intake manifold or vacuum leak, but neither I nor the shop can pinpoint it.
And didn't somebody say they couldn't get the stock connector onto the MSD coil? There is a rubber thing inside the MSD coil you gotta remove before you can push the connector in,, if that guy sees this......
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Had the same prob...just removed it.
Hector
257HP/259TQ
160HP/141TQ
Posts: 281 |
Kremit... we're both running autolite DP's and what u described sounds exactly like my problem.. hmmmm I may just pony up and try the motorcrafts. Let me know how the new coil works out. good luck
Posts: 21,653 |
Well, that's the only time it happened and everything is good. I have an intake or exhaust leak hindering me, but that's another story. AFAIK, autolite and motoc are the same.
98.5 SVT
