#831288 12/30/03 07:41 AM
SVT648 Offline OP
Anyone know if any aftermarket company makes a good engine management system that can run off a laptop for the 'Tour? I know of some for other cars, they can use the laptop for that Superchip type upgrade, then unplug it and retain stock ECU settings. I am only interested because of the infinite amount of tweaks you could make. (Instead of the one burn for a Superchip or Diablo)
1998 Black SVT SHOShop Off-road Y pipe Side Moldings Removed Clear Headlights Open K&N Intake
#831289 12/30/03 01:17 PM
Yes the TwEECer is the only thing offered but it can only be used for the XGT1 computers that were implemented in the 2000 models which are returnless cars. Some guys have hacked an Emanage to work as well. See warmonger for details.
#831290 12/30/03 02:57 PM
W
W
Good Luck!
You have a 98 and I have a 99. The Tweecer doesn't support anything else!
I use the GReddy eManage and it works pretty good and can give you some tunability depending on what you are trying to do. THe timing control section of it won't work on our cars without extensive additional controls that are costly. Everything else on it works quite well though.
#831291 12/30/03 08:32 PM
F
F
Be prepared to pay through the nose! However, you retain the EEC-V
http://www.superchipscustom.com
#831292 12/30/03 09:06 PM
F
F
Autotap and obd-2, you can find them on the net. I don't know what that other product is that our fellow's have mentioned.
#831293 12/30/03 09:16 PM
Umm you can't modify the ECU with those you know.
