Page 4 of 4 1 2 3 4
#83136 11/27/01 09:27 PM
Thanks for the input. I am looking to get good quality sound, not compete. Right now I am looking at car alarms before I start upgrading my stereo anymore, and this one is awesome...
http://www.crimestopper.com/superpage.html
N-VJ - looking at the amp specs it gives the wattage @ 14.4 volts, isn't my battery running 12v???
If you don't wanna follow the link, at least check out the keychain remote. I love electronic toyz..
2000 CSVT #1172 of 2150
Toreador Red...Birthday -> 1/4/2000
*Indiglo Gauges
*Drop in K&N
*Sylvania SilverStar Highs in Lows
*Fog light Fix
*Pioneer Premier P730
*Sound by Audiobahn
*White HVAC Panel
*Security via Ungo MS2007
*Elky Mesh Mod
#83137 11/27/01 09:59 PM
The alternator puts out ~14.4V when running.
You'll tend to see higher end companies rate their amps in the 12V range. They will generally produce significantly more power at 14.4V.
Companies that rely more on marketing like max power, etc... will tend to rate their amps at 14.4V.
This is why a 200x2 amp from PPI, MTX, etc... will cost significantly more than that 200x2 Jensen, Boss, etc... amp.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#83138 11/27/01 10:23 PM
N
N
http://caraudio.udm.net/Amplifiers/usacoustics/USA6300/index.html
That site says the specs are rated at 12.9 volts, so maybe sounddomain is wrong. I've read on other forums that US Acoustics rates their products at around 12 volts, but I can't verify this myself.
#83139 11/28/01 01:28 AM
I've had a few USAcoustics amps. They're rated at 12.9V.
1999 SVT #900/2760
Born on 1-20-99
#83140 11/28/01 05:57 AM
Originally posted by dnewma04:
If only there was a standard! There are so many variables and so many ways that effeciency rating are taken. Boston Acoustics has flat out refused to publish sensitivity ratings because there are so many methods being used, and so many installation variables that they said they could advertise their pro components as anything fom 83 dB effecient to 92dB.
You mean some companies publish fase claims! wink
And yet thousands will still go out and buy that Pyramid amplifier that is 400x4 with a 60 amp fuse and a compact 10" long......or it is 20" long with a 10" long pcb inside.....LOL :rolleyes:
Page 4 of 4 1 2 3 4
Moderated by  dnewma04_dup1
