My HU has:
Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
HPF Crossover
Sub-Out Level (-12dB to +12dB) and Phase Control
EEQ Performance Chip
3-Band Parametric Equalizer
Easy EQ (EEQ) switches 5 Factory, 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom) Source Custom EQ Memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front / Rear
So I assume I wouldn't need to implement a crossover for sub, as it is already in the HU. I've heard people say you don't need to replace the rear speakers as it doesn't do much for you. If this is true I could get the audiobahn 6x8's for the front, saving a $100. Where would this extra hundred bucks be spent for maximum reward to my ears?
Also, if I can power the audiobahn plates with only the HU, can't I get a smaller amp to push only my sub (that sub is 350 watt rms...), thus saving even more money so I can blow the saved money on some other mod for my svt...
