Page 2 of 4 1 2 3 4
#83116 11/27/01 04:34 PM
Originally posted by dnewma04:
I wouldn't put too much stock into Audiobahns effeciency ratings. There is something a little shady going on with the published ratings on their subs. It makes me question if they use the same techniques on the components...
Thanks for the info about the audiobahns btw. I just hadn't heard any feedback on them and I can't recommend anything without a trusted source giving positive reviews. smile
Would switching on the hi-pass crossover have anything to do with the efficiency rating? They test 'em at 1000Hz at 1M, right?
Maybe I should by them to check 'em out. Anybody want to buy my Pioneer plate components?
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#83117 11/27/01 04:36 PM
My HU has:
Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
HPF Crossover
Sub-Out Level (-12dB to +12dB) and Phase Control
EEQ Performance Chip
3-Band Parametric Equalizer
Easy EQ (EEQ) switches 5 Factory, 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom) Source Custom EQ Memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front / Rear
So I assume I wouldn't need to implement a crossover for sub, as it is already in the HU. I've heard people say you don't need to replace the rear speakers as it doesn't do much for you. If this is true I could get the audiobahn 6x8's for the front, saving a $100. Where would this extra hundred bucks be spent for maximum reward to my ears?
Also, if I can power the audiobahn plates with only the HU, can't I get a smaller amp to push only my sub (that sub is 350 watt rms...), thus saving even more money so I can blow the saved money on some other mod for my svt... wink
2000 CSVT #1172 of 2150
Toreador Red...Birthday -> 1/4/2000
*Indiglo Gauges
*Drop in K&N
*Sylvania SilverStar Highs in Lows
*Fog light Fix
*Pioneer Premier P730
*Sound by Audiobahn
*White HVAC Panel
*Security via Ungo MS2007
*Elky Mesh Mod
#83118 11/27/01 04:46 PM
If only there was a standard! There are so many variables and so many ways that effeciency rating are taken. Boston Acoustics has flat out refused to publish sensitivity ratings because there are so many methods being used, and so many installation variables that they said they could advertise their pro components as anything fom 83 dB effecient to 92dB.
#83119 11/27/01 04:55 PM
That's close to what I'd do. Get the front speakers and get a 4ch amp. Run the amp's front channels to the front speakers and bridge the amp's rear channels to the sub.
Then, just run your rear stockers off the head unit. If you can, cut the highs and the low bass to them.
1999 SVT #900/2760
Born on 1-20-99
#83120 11/27/01 05:06 PM
If you want to save a few dollars, than absolutely! The HU would probably do a find job powering the Audiobahns, use the stockers in the rear doors.
#83121 11/27/01 05:15 PM
Thanks for all the great advice! Any recomendations on 4 channel amps for that sub and box? What kind of wiring do I need to run to the amp, I read that the stuff that comes with the amps usually is sub par. Also, how hard is it to install the sub/amp yourself. I would much rather put in the time/energy and learn how to do everything myself so I understand it to troubleshoot in the future.
*Indiglo Gauges
*Drop in K&N
*Fog light Fix
*Sound by Audiobahn
*White HVAC Panel
*Elky Mesh Mod
#83122 11/27/01 05:26 PM
All I really need is Something to handle voice well, the sub handles bass. I saw some Sony 5x7s and there not worth a 119.
2002 Mitsui Lancer-Black MTX.
#83123 11/27/01 06:19 PM
For drop-in simplicity, I'd go with these Audiobahn plate components for $100. Very efficient with external, switchable crossovers.
Audiobahn 6x8 Plate Components
[img]http://store6.yimg.com/I/competitiondirect_1657_57261245[/img]
The Crystal 5x7s from www.mmxpress.com are supposed to be excellent speakers with external crossovers. Unfortunately, they're now $175 for two pairs (used to be $145).
Crystal 5x7s with external crossovers
The cheapest drop-ins of the 5x7/6x8 variety that I can find are these other Audiobahn plate components at $46. I just wouldn't use them without a sub, and I'd make sure to use a hi-pass crossover with them. No external crossovers, tho.
Audiobahn Plates
[img]http://store6.yimg.com/I/competitiondirect_1657_57889114[/img]
IMO, Rockford Fosgate and Cerwin Vega both seem a bit overpriced for what you get, especially when you go to BB/CC for the 200% markup. With a little bit of work/research you can put together a set of custom components that will shame them for ~$75.
Cthomp21, thanks for the great, informative email with great pictures. However, I would suggest the Cerwin Vega HED-1683. I got them for $80 from a website in California, $6 to ship, they drop right in and sound excellent. For Best Buy's price ($119), no. For $80, fine.
#83124 11/27/01 06:33 PM
Sorry, didn't mean to repost the pictures, I'm new at this. frown
#83125 11/27/01 06:37 PM
Sure you don't mean these?
Cerwin-Vega Stealth SS-2683
Stealth Series 5"x7"/6"x8" Speakers
or these:
Cerwin-Vega HED-1693
6"x9" Speakers
please more info on the CV...
*Indiglo Gauges
*Drop in K&N
*Fog light Fix
*Sound by Audiobahn
*White HVAC Panel
*Elky Mesh Mod
Page 2 of 4 1 2 3 4
Moderated by  dnewma04_dup1
