Page 1 of 3 1 2 3
#830091 12/28/03 07:35 PM
9
I'm trying to think of reasons why the Mystique has been getting VERY bad gas milage lately. It hasn't been making the "moosing" sound though. I just changed the plugs and cleaned out the UIM/LIM. Any ideas?
I'm sure the winter gas mix and cold weather hasn't helped but it seems worse than it should be. We had just shy of 200 miles and a little under 1/4 tank of gas left (yes it was filled up completely).
Could the IAC be partially stuck? It isn't moosing....
Aside from the bad gas milage it runs fine. No problems whatsoever, aside from the gas milage.
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
#830092 12/29/03 03:17 AM
o2 sensor,tire presure, fuel,and air filter, even if you dont have a checkengine light on changeing the o2 sensors can make a big difference,
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
#830093 12/29/03 03:57 AM
9
Tire pressure is at 42PSI all the way around (max is 44 according to tires). Fuel and Air filters weren't changed very long ago(10k miles or so).
o2 sensors on the other hand have never been changed... that could be good to check out... Thanks!
#830094 12/29/03 10:54 AM
#830095 12/29/03 03:45 PM
If you change the O2's, just replace the uppers as the do all the calibrations that count This is why I always check my MPG, just to see what its doing BTW, is your O/D working correctly? The reason I ask is because if its stuck in regular DRIVE, your mileage will suffer some, especially on the freeway.
#830096 12/29/03 05:10 PM
I've been getting crappy mileage from day one. Bought it in Georgia & drove down to Florida. The first tank of gas 33 mph. Next tank it dropped to 27, now 23 mpg every day in mixed driving.
I visited the hills of Tennessee in October for some HARD driving & my mileage jumped to an average of 28 mpg. Over 32 mpg on the first leg on the way back.
I think it has more to do with the gas than anything else. I may change my O2s some day - just to see if there's a difference, but for now I'll just pay N pay N pay for the extra fuel.
#830097 12/29/03 10:49 PM
Yea I've noticed the Duratec does like to get abused. I get the same gas milage beating the living snot out of my Contour as I did when I drove it normally. My 6 is getting about 23 for mixed, now it has 1400 miles on it. Yes 1400
Mazda 6S, V6, Speed Yellow 5 Speed, Sport package Bose audio Painted 'stash and HIDs! w/Injen 1/4 14.750 @ 94.94 Former car: 99 Contour SE Sport Black MTX V6 SVT plastic... 1/4 - 15.012 @ 90.58
#830098 12/30/03 03:01 AM
9
Yea they do... we got 29 on a trip to the cottage last summer... I drove it pretty hard too...
It does go into overdrive, tranny is working fine.
#830099 12/30/03 03:46 AM
Is the temp gauge coming up to normal or is it staying low?
If the engine is always running cold, you will get crummy gas milage because the processor will think that the engine isn't warmed up yet and stay in "choke" mode.
#830100 12/31/03 01:06 AM
9
Yea, it comes up to normal...
Page 1 of 3 1 2 3
