#827906 12/24/03 07:00 AM
F
F
cel light keeps coming on, shows code P1131- h02511, i know it's the o2 sensor but which one, front or back and any ideal how expensive they are.
#827907 12/24/03 07:11 AM
That one is the rear (next to the firewall) upper sensor (before the precat). It's also the hardest to replace. I was able to do mine a few years back fairly easily by renting a free O2 sensor replacement tool from AutoZone. The kit included an offset 3/8 drive socket that you just put a few ratchet extensions on, lay on your back and twist the sensor right off.
Before you do this you might do a search for "1131" and read about some of the other people here who have had the same code. Not all have been a defective O2 sensor.
#827908 12/24/03 07:23 AM
F
F
i was told by ford it was the front, good thing i checked before i bought it, also they say it's $164.66 for 1 sensor.
#827909 12/24/03 07:42 AM
That's quite expensive. AutoZone also sells the sensors. I don't remember exactly what I paid a year or two ago but it's not anywhere close to $164. If you don't need it by tomorrow you can get a huge CEG discount through Bill Jenkins at Signature Lincoln Mercury in Las Vegas. Contact info is at the bottom of this link: CEG Parts Sources
Remember, do a forum search first before you replace the sensor. People have reported things like bad wiring, corroded plugs and manifold vacuum leaks causing this code to appear.
#827910 12/24/03 01:29 PM
Sensor is about $65 at AutoZone for a unit from Bosch. Excellent quality part.
Replacement is a bit of a PITA, but what isn't?
Steve
