#825785 12/21/03 11:29 PM
Bellaco Offline OP
Anyone know where I can find directions on taking apart my headlights so I can clean out the moisture. Post '98.
#825786 12/21/03 11:52 PM
Don't take them apart. You'll end up with the same leakage problem as most have experienced with taking them apart.
You obviously have some kind of leaking in your lights.
Take them off the car.
Fill one with water and try to figure out where it's leaking from.
Set them in the sun without bulbs in.
Use some silicone or aquarium sealant to seal the area that's leaking.
Let sealant dry.
Once they are dry, consider swirling some alcohol inside to "clean" them.
The alcohol should ry fairly quickly.
HTH
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#825787 12/22/03 12:01 AM
Bellaco Offline OP
I guess I'll give that a try. Damn, I really wanted to use the dremel too!
#825788 12/22/03 01:06 AM
Use the Dremel, only, ONLY, if you are wanting to paint the inside chrome. Otherwise, listen to PETE.
1992 Ford Escort LX-E -Tracer LTS spoiler -GT Grille
#825789 12/22/03 05:36 PM
CEG road warrior
CEG road warrior
