#824461 12/19/03 04:55 AM
I recently (1500 miles ago) changed my water pump as a part of preventative maintenance. I put on a pump with a cast iron impeller, used gasket sealent(on both sides) and reused all 8 bolts. Then I found out that 3 of the 8 bolts (the bolts that hold the pump to the head) are not supposed to be reused because the are "torque-to-yield" bolts. Do I have a problem here? Also, I didn't use a torque wrench when installing the new pump, just installed them to what I thought was reasonable. No leaks (yet).
#824462 12/19/03 05:41 AM
H
H
Where did you read/see/hear this? The Ford service manual makes no mention of any TTY bolts on the water pump. In fact, it specifically mentions when TTY bolts are used on components, like on the crankshaft pulley.
FYI the torque to be used on all 8 bolts is 18Nm.
#824463 12/19/03 04:59 PM
In Haynes manual, it suggests not reusing the bolts because it it torque-to-yield. I had questions about that myself, when I wanted to replace my waterpump. From the previous posts, I assume people had no problems reusing them.
#824464 12/19/03 05:34 PM
Webmaster
Webmaster
I had no problems reusing mine. That was in Aug 2000.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
#824465 12/19/03 05:46 PM
H
H
Crap, my brother has my Haynes manual so I can't check it. Honestly, though, I'd trust my Ford manual from todras over the Haynes manual anyday. I like my Haynes manual, don't get me wrong, but I've heard of a few things that they got wrong.
#824466 12/19/03 07:51 PM
I recall reading in the 1996 Ford service manual (I have it on CD) that the water pump housing to engine blcok bolts on the Duratec are TTY.
#824467 12/20/03 12:31 AM
My manual says they are TTY bolts. But I reused them and have had no probs at all...
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#824468 12/20/03 03:16 AM
I got the "do not reuse bolts" info from Chiltons. I bought the manual after the pump replacement.
#824469 12/20/03 06:16 PM
I don't see any mention of the water pump bolts being TTY in the Haynes manual
6k miles since I reused mine, no problems *knock on wood*.
Chris G. ~ 98 Mystique LS ATX
#824470 12/20/03 11:54 PM
The idea behind TTY is that the fastener is stretched to the elastic limit of the metal. (the elastic limit is the ammount something can be stretched and still return to its original dimensions when the force is removed) The problem with reusing TTY bolts is that although they return to their original dimensions when removed the metal is stressed and tightening them to TTY again will possibly result in distortion and/or weakening of the fastener.
For their purpose the waterpump bolts will liikely never have a problem if they are reused. But if you were to reuse a TTY bolt that is used for a high load application like a connecting rod cap, main bearing cap or cylinder head then you might have a problem.
I feel sorry for the people who don't drink. When they wake up in the morning, thats the best they're going to feel all day - former President Lyndon B. Johnson
