While you should be able to get a non-VCT Focus head to fit a non-VCT Contour Zetec, you need to check all the attchament points for the accesories... Assuming the Focus head has all the required mounting poiuts you should be able to do a transplant.
Check the cam gears and the cam drive assembly while you are at it.
