CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by TourDeForce:
I'm gonna find out once & for all if the ZXtuner 4-2-1 headers will fit the Contour. Some of you guys may have to add an EGR bung, but that'll cost a whopping $30 or so to have a shop do that. If you wanna be totally leagal, you can even add a cat AFTER the flex pipe like for the V-6. Extending the wiring for the O2 sensor should cost next to nothing if you're handy enough to use a $7 soldering iron.
Easy for you to say........my whole downpipe was fabricated PLUS both o2 sensors had to have bungs made.....what a PITA!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 7,117 |
Awrite Hector. You got some good gains out of the setup I see - very cool. Right now I'm just trying to find out if the Contour setup is similar to the ZX2 under the car so we can perhaps make use of some aftermarket parts. I have a ZX2 to compare, but I need the pictures of a Zetec Contour under the car as described. If you or one of the other CEGers reading this thread can send along some pictures, we'd all appreciate it...  Did you start with the 4-1 race header for a ZX2? Were the headers designed for a Focus? Need input & photos.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by TourDeForce: Awrite Hector. You got some good gains out of the setup I see - very cool. Right now I'm just trying to find out if the Contour setup is similar to the ZX2 under the car so we can perhaps make use of some aftermarket parts. I have a ZX2 to compare, but I need the pictures of a Zetec Contour under the car as described. If you or one of the other CEGers reading this thread can send along some pictures, we'd all appreciate it...
Mine was for a ZX2.....both the ZX2 and Focus downpipes are routed the wrong way around the oil pan....our oil pan on the Contour is "switched around" not to mention the o2 sensor bung on the header originially was directly next to the a/c condensor so the top o2 sensor wouldn't fit.
Hector
257HP/259TQ
160HP/141TQ
Posts: 7,117 |
Originally posted by LoCoZ: Mine was for a ZX2.....both the ZX2 and Focus downpipes are routed the wrong way around the oil pan....our oil pan on the Contour is "switched around" not to mention the o2 sensor bung on the header originially was directly next to the a/c condensor so the top o2 sensor wouldn't fit.
Cool, progress. Not good news, but progress. The research continues, and I recon we wait for the CC or ZXtuner headers to hit the market. Seems those will be the best bet rather than trying to fab something to fit.
Thanks a million for the info!
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by TourDeForce: Originally posted by LoCoZ: Mine was for a ZX2.....both the ZX2 and Focus downpipes are routed the wrong way around the oil pan....our oil pan on the Contour is "switched around" not to mention the o2 sensor bung on the header originially was directly next to the a/c condensor so the top o2 sensor wouldn't fit.
The flexpipe was relocated along with the cat.
Hector
257HP/259TQ
160HP/141TQ
Posts: 8,143 |
is there enough room to add a cat...looking under the car and with the space of where the flexpipe is now and the downpipe & cat...doesn't seem like theres enough room.
Posts: 7,117 |
As suggested, a main high-flow cat can be installed after the flex pipe. The main cat is pretty far back on the Duratec engines and does a good job of scrubbing the exhaust.
Posts: 8,143 |
Originally posted by TourDeForce: As suggested, a main high-flow cat can be installed after the flex pipe.
i know, doesn't seem like theres enough room for a decent size cat.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ZetecNinja: Originally posted by TourDeForce: As suggested, a main high-flow cat can be installed after the flex pipe.
Where do you think mine is?
Hector
257HP/259TQ
160HP/141TQ
Zippy Zetec on his last legs.
Posts: 1,262 |
Originally posted by LoCoZ: Originally posted by ZetecNinja: Originally posted by TourDeForce: As suggested, a main high-flow cat can be installed after the flex pipe.
fair guess, the trash can???
i hate cats..they suck
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
