Posts: 2,071 |
So I finally have found a clay bar and now have a question. Is it supposed to be soft? It's like it has melted or something. I was under the impression that it is supposed to be like a bar, not a gooey sorta hard thing. TIA, Mike
Former - 98 CSVT E0 T-Red 4/4/97 #173 of 6535
Dear Santa
Posts: 9,196 |
Congrats on the clay bar, you'll be amazed after you do the first panel  As far as it being soft, it supposed to be that way, all of em' are. What brand did you buy and whats "Project Amber"
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 9,442 |
Originally posted by The Striped SVT: whats "Project Amber"
Ditto
Posts: 305 |
The clay bar is soft and plyable, like a kneadable eraser. Make sure you turn the bar over on itself lots so you don't rub the junk you took off all over your paint and create swirls. Clay bars are amazing! Good luck.
'99 Silver Frost.SE.V6.MTX
Drop-in K&N / Masked rear Reflector
st200/Eibach / SVT E1's
FMS Wires / ES Rear Bushings
Posts: 2,071 |
Thanks guys, I was thinking it was kinda weird but wanted to make sure. It only took me like a year to find the friggin thing.
I can neither confirm nor deny any details of the alleged Amber Project. It is possible that my sig has been hacked and what you see is not really there. muahaha
Dear Santa
Posts: 9,442 |
Originally posted by 69Boss302: I can neither confirm nor deny any details of the alleged Amber Project. It is possible that my sig has been hacked and what you see is not really there. muahaha
Posts: 9,196 |
Another "tip" for the clay bar is to break it into a couple pieces. This way, if you happen to drop it on the ground and it gets all dirty, you can just throw away that small piece instead of the whole thing
"THEE" Roger R
USMondeo@aol.com
Posts: 189 |
What is a clay bar used for?
Posts: 9,196 |
Originally posted by Dtox: What is a clay bar used for?
The clay bar is used when your paint isn't very smooth to the touch anymore, like after you wash it and you feel this "grit" still on the paint surface. It removes the embeded contaminents from your paints surface so when you wax your not putting that clean, new wax onto a "gritty" surface. This will net you "professional" results and you'll be amazed you went w/o it for so long Once again, thanks to APT for showing me the light!
"THEE" Roger R
USMondeo@aol.com
Posts: 1,746 |
Should feel about as soft as silly putty. It shouldn't be oozing or anything like that.
