Posts: 91 |
Thanks for the suggestions. I will try to clean the filter on the fuel pump first and the main fuel filter - cheapest option.
06 Mustang GT - stock
96 SE V6 5spd Midnight Red - 15.9 @ 86.8
150K miles
Mods: Bilstein struts, H&R springs, Borla Cat-Back, Brullen y-pipe, Gutted Precats, SVT UIM+LIM+TB, K&N FIPK, , DMD, Magnecor KV85
Posts: 429 |
This isn't your problem, but I will mention it anyway FYI. My brother recently had a hard start problem with his '99 Camaro. After consulting the local dealership, it turned out to be the fuel pressure regulator. He changed it and now it starts fine.
Dan B.
96 SE 2.5 auto
Posts: 2,408 |
Originally posted by lobudgetraceing:
a bad gas cap will release the wacuum from the tank and cause a check engine light.
the vacume that builds in the tank is normal.
The gas cap is meant to keep fuel vapor from being released to the atmosphere. The vapor under pressure is routed to the carbon cannister, and later sucked into the engine and burned. Fresh air enters the gas cap through a small bleed valve to prevent vacuum in the tank. Excessive vacuum in the gas tank lowers available fuel pressure.
Posts: 2,408 |
Originally posted by NJE96SE: When you say it could be the pump screen, what do you mean? How would I go about testing the fuel pressure?
Remove the back seat and the cover on the floor. Disconnect and pull the pump through the hole. There are upper and lower intake ports which have a screen and filter sock. Clean these and reinstall the pump.
Fuel pressure is checked at the Schraeder fitting on the fuel line near the engine. This is the same fitting as your tires have.
Posts: 95 |
mine has the same problem, but all the time, not when fuel is low, do i have the same problem?
_________________________________________________
Contour 98.5 GL V6 Manual, 115,000 KM
(actual modifications) magnaflow exhaust
K&N induction kit, sport chip, resonator removed.
iridium plugs, heat deflector,nology wires, no pre-cats.
Posts: 91 |
I do have this problem all the time, but it is worst and most noticeable when fuel is low. You might have the same problem. At WOT and high rpm's it is not noticeable.
150K miles
Posts: 1,165 |
Had this problem on my mom's SE.
New fuel pump installed. Problem gone.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 28 |
If your hesitation occurs when the fuel is low and progressivly gets worse the lower it goe,s then I would say it is a fuel pump problem. I just had mine replaced at 45,000 miles. The hesitation on mine turned into bucking, but since the fuel pump was replacement I have had no such problem. I still have the slight hesitation when I try to get on it hard witrh low rpms. I'm not sure what this problem is. The tour almost acts like it is waiting for the secondaries to open before it is ready to go. If this is your problem I would love to also find out a solution.
