Posts: 2,066 |
Has anyone been able to place their 10disc changer anywhere other than Trunk.
I should be getting my new changer soon so I figured I would ask.
I haven't measured yet but I was going to check out the center console. I hardly ever use it but I was thinking if I took out the black inner casing(If it comes out) I could possibly put the changer in there. Again I am not even sure if it will fit. Hmm...I'll go have a look.
What do you all think? I just don't want to put it in the trunk.
Thanks...oh and pictures are welcome too.
Later
Posts: 107 |
Under the passenger seat? I think some of the Mondeos fitted with a CD-changer at the factory had them mounted there. Only 6-disc though so I don't know if a 10 will fit.
'93 16V Mondeo saloon Full factory RS setup lowered on 17s K+N 57i, splitfire leads, chipped, full aluminised twin-exit exhaust Sounds by Alpine, Infinity, Vibe, JBL First Mondeo with indiglo gauges
Posts: 3,165 |
I've heard of people mounting them in their glove box. That is if you don't need to keep anything in there.
Posts: 63 |
I have a clarion 12 disk changer under the passanger seat soon to be a 6 disk in the glove box.
99' Silver Frost SVT 18" Racing Hart C2's Color matched Headlight covers Ding guards removed Custom intake B&M Short Shifter Koni's and Ground controls NGK Iridium plugs
Posts: 76 |
I have a 8-disk in the glove with room to spare. At first I thought it wouldn't work either but once I got the changer and saw how small it is, there was no problem. Love it. :rolleyes:
1996 GL Red Contour, Zetec, ATX K&N Filtercharger,aluminum mesh grill OBX Fog Lamps, Viper alarm FocusSport High Performance 8mm Spark Plug Wire, LEVOC custom ATX shifter Panasonic CQ-FX620U Head Unit, Panasonic CX-DP88 8-disk changer, Infinity Kappa 572.5 Front/Rear JCWhitney 80W Xenon Headlight low beams CEG sticker, Bridgestone Potenza RE950 Magnaflow SS Race Series#14830 & Resonator #10424
Posts: 107 |
I used to keep my Alpine 6-disc in the glovebox, but my main concern was security. Even though the '93 Mondeo has a lock on the glovebox (does the Contour have this, 97+ Mondeos don't?) it would be relatively easy for a thief to force it open by breaking it.
My changer now goes in the boot, but I'm toying with the idea of putting it under the passenger seat since it would take some time to remove the seat to steal it.
Paul.
Posts: 1,041 |
Ok So is it possible to mount a 12 disc Clarion Changer in the glove box? Anyone know for sure? I'd assume some cutting is of course necessary, but over all would it fit.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 19 |
I use the Alpine 6 disk changer in my glove box. It's nice and handy for changing magazines. I'm not sure that a locked glove box would deter thieves.
Anything larger will not fit, imho, but I may be wrong.
