Page 3 of 3 1 2 3
#818750 12/15/03 06:00 PM
E
E
Originally posted by Mattyv12:
Originally posted by ESC:
How much do you have to clear the rim by to be able to dunk? I can grab the rim @ 10' but do I have any chance of improving my jump enough to ever dunk?
I'm am only about 6'1" and since starting a jump workout along with lifting weights three times a week I have gained about 7" on my vertical leap in the last year or so. So I would say that ya you have a chance to dunk if you keep workin on it
Any recommendations for a jump workout? Books or website. I'm 5'8" so I have a lot of ground to make up for.
#818751 12/15/03 06:27 PM
F
F
I'm not a ball player but I did play a lot of competetive beach volleyball when I was younger and I had a pretty good jump back then. Here's what I did that worked really well for me:
I built 3 boxes out of wood that were 1,2 and 3 feet high. With feet together you jump up on the boxes starting with the 1' then moving up to the 2 and eventually 3' all in the same workout. Reps depends on where you are physically so you'll have to try it out to get a feel for how many to do. Basically just do it until you're burnt out. After a while you can start adding weights using ankle weights or a medicine ball or whatever kind of weights you have to use. Also, when weight lifting do a lot of squats and calf raises. If you can't build the boxes you can do it on stairs, bleachers or whatever you've got available to jump on. (not the hood of your car though ) This method helped me out a ton back in HS. Or, you could just buy some Air Jordan Nikes, I heard they automatically increase your jump by like 2 feet.
Formerly known as Sneaku I MISS MY BABY!!! '00 Blk CSVT #1087/2150 built 12/23/99
#818752 12/17/03 06:03 PM
Originally posted by JVT:
LoL, haven't seen that before. Great vid.
Having said that, it'd be nice if you could learn how to post a fuggn link ya jackass!
And in the right forum, to boot.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
Page 3 of 3 1 2 3
