Posts: 31 |
I can't remove my key from my 97 ATX Contour. It will start the car when I want to park, I cannot turn it back past ACC. as a result,I can't remove the key. And as an added bonus, the battery runs down since the the key remains in the ACC position. Is this a problem with the steering locking mech. or is it from the transmission lock out switch(the one the only lets you start the car from P or N) My gut says it is the steering column locking device. What do i do? Where do I look to fix this. Thanks
Posts: 195 |
Maybe too simple, but did you try wiggleing the gear selector in park while removing the key?
1998 ContourLX V6 ATX
Cats Gutted+MIL Eliminators
Grandma gave me the finger
Posts: 808 |
I could pull my key out of the ignition when I was driving the car! I don't know about yours but if yours is the same then crank up the car. Take out the key and use just the tip to shut the car off.
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003
94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons.
02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
Posts: 31 |
Yeah,I tried the jiggle technique. I got it to come out once, but something is up. I don't want to chance it ripping out out with force. Nor do I want to go to the stealer-ship. Suggestions? Thanks
Posts: 2,319 |
Possibly the key removal inhibit solenoid (located on steering column) is not having its feed interrupted by the transmission lever position sensor (located in console), try pulling fuse 34 interior fuse panel to see if key can be removed.
Posts: 3,395 |
Yep, make sure when you turn the car off, make sure you cant shift, if the shift selector is able to move, theres your problem, also if that fails, unplug the battery, i know that will let the key come out.
--Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
Posts: 72 |
Try removing the console around the shifter. There is a switch in front of the shifter that tells the key solenoid that the shifter is in Park. Make sure the switch is seated in the holder.
My daughter had this problem. The switch is plastic (suprise)and the ears that hold it in broke. You can get a new switch or glue it back in.
John Alessi
Torredor Red #1915 of 2150
Born 27Jan2000
G/S No serious mods allowed
1986 SVO Mustang
Posts: 3,395 |
Originally posted by SVT2000Contour: Try removing the console around the shifter. There is a switch in front of the shifter that tells the key solenoid that the shifter is in Park. Make sure the switch is seated in the holder.
Or rip wires apart and try shorting em out till it works!!!
Posts: 2,408 |
Take the shroud off and use a paper clip in the retaining hole to pull the lock cylinder out. Take it in somewhere well lit and work on it.
