Posts: 1,145 |
is it possible to put the SVT gauge cluster in a SE and if so would you need to change anything  and YES i searched so poo on you
98.5 Black SE ATX
Posts: 1,231 |
-06 GTO Torrid Red/M6
-98 LS with BPU
-05 Honda Odyssey EX-L
mv .zig ..\for\great\.justice
CEG road warrior
CEG road warrior
Posts: 17,248 |
Search again......I have SVT gauges in my Zetec Contour...have to wire up the tach....well maybe.  Ford decided to get rid of the tach signal wire in 99 and 00 Contours.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,145 |
no i have a tach already and its a v6 so should everything work right if i just plug it in
98.5 Black SE ATX
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
160HP/141TQ
Posts: 7,025 |
it will work. However, your fuel gauge and coolant temp gauge may read backwards. If thats the case, just peel the faces off those two and put them on your stock gauges.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 802 |
or you can buy custom made gauge faces at www.importcarpartsplus.com any color you want!
New Pics of OUTKAST 1!Sept2006
Posts: 1,145 |
why might they read backwards???
98.5 Black SE ATX
Posts: 2,007 |
Originally posted by gearhead98: why might they read backwards???
Probably polarity being switched somewhere in the connections.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 1,145 |
if i switched the wires would it read correctly instead of switching the stickers cuz i will go crazy thinking my gas is goin up and down all the time
98.5 Black SE ATX
