Page 2 of 2 1 2
#81713 10/19/01 04:23 AM
Originally posted by KnuKonceptz:
I had the H600 and 7949, Loved them both although it did not like cd-r's very much. Best sounding system I ever had was with those two units. I recommend it, I have a second one sitting here, still deciding on if i want to install it in the SVT or not, there new H510 looks goo too though.
Hey Knu,
Mine never had a problem with CDRs up until a couple weeks ago...it has trouble finding the first track usually. Its been acting a little strange in the last few months. Can I contact Alpine about sending it in for some maintenance/upkeep? You know, check things out, clean up the tracks and the lens/mechanism? TIA.
#81714 10/19/01 04:45 AM
Hey Paul in reference to your questions check out my post HERE
Mike | 98 Silver CSVT
#81715 10/19/01 07:21 PM
Paul M Offline OP
SQPlus, I the headliner in my car looks much the same as yours (even the interior light and map light assembly looks exactly the same). The only difference is the large plastic panel behind the light where the sunroof motor and switch go.
If I get the PXA I'll look into placing the control panel when I actually have the unit in my hands. It's easier to try things out that way. Although I'm sure if it's thin enough I could get it behind the visor and fit something to make sure it doesn't get scratched by the mirror cover. BTW, does your mirror cover open up to reveal two small lights either side of the mirror? In that case it will be the same as mine also!
Is it true that the PXA-H510 doesn't come with a microphone and the ability to perform an automatic setup? I believe that unit is more suited to a multimedia install (hence the DD and DTS) and it loses out on some features of the 600. Probably needs the use of an RTA to set it up properly.
mklaro, I read your post, are you sure it's the 7878 you got? Over here that is the MP3 unit but you state it's the unit below the 7878. I think you've got the 7876 which has a segmented display rather than dot matrix and doesn't support MP3 or CD-RW (but it does have a 4x60W max amp).
Paul.
'93 16V Mondeo saloon
Full factory RS setup lowered on 17s
K+N 57i, splitfire leads, chipped, full aluminised twin-exit exhaust
Sounds by Alpine, Infinity, Vibe, JBL
First Mondeo with indiglo gauges
#81716 10/19/01 07:29 PM
Unfortunately my car(98.5) was caught at the beginning of the decontenting so no I don't have the lights in my visors. mad Damn Ford. I imagine you could affix some soft material to the mirror cover so it wouldn't scratch the face. Another concern I just realized is with the way head liner curves to fit the visor. It is 'sunk in' closer to the actual roof so the visors are inset. The depth behind there might not be enough for the display. I'm going to go and check it out right now though. I'll snap some pics of the unit so you can see it better. Back in a flash. laugh
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
