SQPlus, I the headliner in my car looks much the same as yours (even the interior light and map light assembly looks exactly the same). The only difference is the large plastic panel behind the light where the sunroof motor and switch go.
If I get the PXA I'll look into placing the control panel when I actually have the unit in my hands. It's easier to try things out that way. Although I'm sure if it's thin enough I could get it behind the visor and fit something to make sure it doesn't get scratched by the mirror cover. BTW, does your mirror cover open up to reveal two small lights either side of the mirror? In that case it will be the same as mine also!
Is it true that the PXA-H510 doesn't come with a microphone and the ability to perform an automatic setup? I believe that unit is more suited to a multimedia install (hence the DD and DTS) and it loses out on some features of the 600. Probably needs the use of an RTA to set it up properly.
mklaro, I read your post, are you sure it's the 7878 you got? Over here that is the MP3 unit but you state it's the unit below the 7878. I think you've got the 7876 which has a segmented display rather than dot matrix and doesn't support MP3 or CD-RW (but it does have a 4x60W max amp).
Paul.
'93 16V Mondeo saloon Full factory RS setup lowered on 17s K+N 57i, splitfire leads, chipped, full aluminised twin-exit exhaust Sounds by Alpine, Infinity, Vibe, JBL First Mondeo with indiglo gauges
