Page 2 of 2 1 2
Originally posted by 98.5_SVT:
Originally posted by CUTTOUR2624:
1)There is a TSB out on it.
2)There is a updated IAC & hose
So will Ford replace it with the updated parts for free since there is a TSB?? Or is this something that would be covered under an ESP??
TSB's do not provide an exception to normal warranty. A TSB is not a recall. A TSB provides information to help with repairs but does not authorize paying for repairs past warranty.
It might be covered by ESP, depending on which ESP plan you have. A service advisor could check coverage if he has your VIN and the basic part number from the TSB.
I recently replaced both the IAC & tube with Fords "new & improved" pieces. Guess what? It still mooses and I also have the TH fix. Funny thing though, I've owned my car since day 1 and it never "moosed" before. Mechanical or other wear issues can cause it.
There's a much bigger issue here, as in poorly designed (from a resonance viewpoint) inlet system. Do a search, you'll find plenty of info.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
Page 2 of 2 1 2
