Page 2 of 3 1 2 3
#816707 12/09/03 11:25 PM
hehehe, I will need an alignment though afterwards correct? I had an alignment done about a month ago and I don't know if it was like that when it was done, but my car wasn't vibrating then...If I don't need one, I'll just do it myself. How hard is it to re-align the eccentric head when putting it back on? Since that is what controls the toe setting, I just need that right and I shouldn't need to get an alignment afterwards, correct?
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#816708 12/09/03 11:51 PM
Easy job. You won't need an alignment cause you're not moving the rear subframe at all.
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#816709 12/10/03 12:25 AM
If there are any eccentrics involved mark their positions with a scratch-all in at least two spots, that way they can be repositioned when reassembling.
Sarge43 "00" Tique 2.0L I4 ATX "98" Mustang 3.8L V6 AT The reason there's so much ignorance is that those who have it are so eager to share it.
#816710 12/10/03 01:02 AM
cool, i'll just do it myself then, thanx a lot everybody.
#816711 12/10/03 02:34 AM
If your alignment was correct before you bent the arm, and if you didn't knock anything out of alignment when you bent the arm, and if the new arm is exactly the same length as the old arm, and if you put the cam shaped washer back in exactly the same position it was in before, then you won't need an alignment.
#816712 12/11/03 09:07 PM
V
V
front control arm in my 98 svt was bend a little, replaced it didn't help my vibration problem.. i am blaming it on the rim that is bent a little.
how do you do the rear alighnment?
what does it do?
#816713 01/29/04 11:20 PM
Originally posted by lsneo:
yea rear ones are easy to replace. Bout 20 min job. dare i say its easier than changing the oil filter..
i'll 2nd that.....
"Here's a mirror, see your stupid face!"
#816714 01/29/04 11:25 PM
back to the future are we?....
#816715 06/15/04 09:54 PM
Does anybody have the torque settings for the bolts that hold on the rear control (track) arm (the thinner, rear one)?
I am replacing two now. Noticed alignment was off after having rear bumper painted last fall. Figured I would leave it until I replaced the tires. Was in getting new tires and an alignment when they showed me that both rear control arms were bent. I think the body guy must have jacked up on them, I don't see how they could have bent otherwise, and I haven't hit any curbs or holes.
One of the washers was cracked and broken, $42 CDN from Ford, for a damn washer.
Thanks.
#816716 06/16/04 02:15 AM
H
H
the thinner rear one to the crossmember is 52-72 ft/lb. to the knuckle its 75-102
Page 2 of 3 1 2 3
