Page 3 of 3 1 2 3
#814416 07/21/04 03:38 AM
just get a coil pack and if thats not the problem, return the new one.
98 contour s.e. sport mtx http://www.cardomain.com/memberpage/503352 all mods shown on page
#814417 07/21/04 09:58 PM
WERD...i just ordered mine from BillJ not 20 minutes ago and its on the way. if it doesnt work then i will try something else and return it but im pretty sure it will work.
E0 silver #185 *3L hybrid+lots of mods DYNO(moderate tune): 205 whp/ 190ftlb http://www.cardomain.com/memberpage/449801
#814418 07/22/04 03:39 AM
in the end my misfire turned out to be a bad injector, aside from the bad plug incident. must be the coil. usualy when its a coil the 2 cylinders that run on the same coil on the coil pack will misifire. like (2-6) (3-4) (1-5). did you make sure the wires are in right. bank 1 is on the firewall side and has cyl 1-2-3 1 being on your left wich is the frotn end of the motor. than the other side in front bank 2 is 4-5-6 4 being on your left wich is the front of the motor.
Page 3 of 3 1 2 3
