Well I have complained a few times that my car, since it's purchuse, has slowly ran hotter and hotter. It normally ran in between the O and R. After about a year or so, it started running in between the R and M, visiting the O only during warm-up's. There was a few times that, out of the blue, the car would run between the N and O! But after a day or so, it would return to running between the R and M.
A few months ago, I replaced the thermostat, but that made no difference.
Yesterday, I noticed that the sensor was slowly climbing over to the far side of the M! I turned the heat on (yeah, it ain't that cold here during the day
) and it slowly worked it's way back down. I was planning to stop off at Autozone to get some ATF, so I went ahead and got a water pump too. It has been on my to-do list forever, just never did it.
I noticed on the way home that traveling down the road, really made no difference in the temp readings. It was running the heater that was saving my tail. I could hear my fans running at low-speed when coming to a stop and also could hear the fans kick into high once I was at a stop or just before. Still, it did not seem to make any difference! The temps would rise to the far side of the M, never quite making it to the A.
I changed my water pump this morning and found nothing wrong with it at all!! And it was one of the plastic one's too!! It was off white in color and not black, so that might have something to do with it. Anyway, 188K on that bad-boy!! WHOO HOO!! I went ahead and installed the metal impeller one anyway.
Anyway! Still no difference! Tonight, after reading some posts from a search - I went outside, let the car idle and just watched everything. The temps raised slowly to the farside of the M and the fans finally kicked in low speed. I felt the hoses several times and squeezed them. I could fell some pressure building (by the hoses getting stiffer) and I could also see the fluid in the coolant bottle move with each squeeze. Before starting the car, when doing this, I could also hear the check valve/bypass valve (whatever it is called) on the thermostat rattle. So I know that is not stuck. After a short while, the temp of the air exiting the fans was almost cool. I checked the temps inside and it was between the M and A! The cooling fans kicked into high and I cut the heater on. Within a minute or too the temps came down to between the R and M.
When pressing on the hoses, on both sides of the thermostat, the fluid in the coolant reservoir would move with each squeeze. Also, after shutting the car off, I was able to remove the reservoir cap with very little hiss and fluid inside was only lukewarm.
With all that, I am wondering if I am dealing with a partially stuck open thermostat or a leaking reservoir cap? Any suggestions???
