Posts: 15 |
well, the antennae is stayin up, and it didnt used to. i know that the amp and ant wires are spliced on to the same wire. could that be it?
Posts: 3,567 |
Originally posted by jsung: i know that the amp and ant wires are spliced on to the same wire. could that be it? thats the prob.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 117 |
My antennae stays up all the time too. On my deck I have an amp turn-on and a power antennae wire. I have the Power antennae wires spliced together, but I always have the antennae up though I never use the radio just CD and or Changer. Antennae goes down when I turn off the deck so I know it works.
Any ideas? I might put in a switch to raise the antennae when I need it. Anyone know how I would do that?
'95 Mercury Mystique LS Praire Tan w/ Tan Leather MTX, Moonroof
Posts: 214 |
I'm pretty sure it involves a DPST switch. I was going to install one myself over the summer, but ran out of time. One of the CEG'rs recommended a push button on the steering wheel column which can raise or lower the antennae manually.
For the life of me, though, I don't know how you would wire it (aside from involving the antennae wire of your system) and how you could run the wiring inside the dash from the head to the steering wheel. Maybe he'll notice this and answer these questions, heh.
98 Contour SE Sport ATX (T-Red) Bonafied Rookie Pioneer DEH-3100 :: K&N Filter :: CEG Foglight rewire
Planned Mods: Test TH Fix in ATX :: Door Lights :: Side Markers
Farther Future Mods: KKM Intake :: SVT Exhaust :: SVT Rear Bumper :: BAT Euro Kit
Posts: 1,444 |
i'd be interested in this. i drive around listening to cd's and the stupid antenna is up and doing nothing.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 95 |
Hey. It's been awhile since I posted. There was a post on this before. It might depend on the stereo you have. The 2 Kenwoods I've had both worked with the power antenna. I'm not sure, but would assume, that other decks should work the same. It should only be the power antenna wire on the deck to the power antenna wire for the car. That should be all you have to do. Check the manials for each deck to see if they work in that fashion.
If not, do the remote switch.
"I've got a lot to learn in so little a time. Oh well!" Do we really have to do the rating system? Mods: Chris Hightower-like Express Open & Close 885 fogs & stereo stuff
Posts: 39 |
Why on earth did you guys splice the power ant and amp on wires together? They both should be seperate. The one for the power ant only sends power when the radio is on. The amp on sends power when ever the deck is on, be it CD/cassette or radio. Splice them together and of course your ant is going stay up. BTW, wish I had a power ant!
"I never realized how stupid the general public was until I started working retail!"
'99 SE Sport ATX(I'm lazy) Badgeless, Vent Gaurds, Stained carpet, Broken air box hold downs(2), Crappy Firestones
Posts: 117 |
Well my problem is I have Power Ant. to Power Ant on my deck, but the Antennae still stays up the whole time. Why? How can I fix that?
Posts: 4,585 |
Originally posted by truxman: Well my problem is I have Power Ant. to Power Ant on my deck, but the Antennae still stays up the whole time. Why? How can I fix that? That's just how your HU works. A switch is the only way.
Posts: 230 |
why do you guys even care if the anttena is up when you have a cd in. you are just makeing your self crazy over nothing.
