Originally posted by dnewma04:
Bill, this is all your fault!
Talk to the engineer at Eminence! He is one of the people on my side I even got the techie at JL to agree with what I was saying!I will talk to (or have my budy relay the message) to Jerry at Eminence. I'll see what he as to say. Shorting the coil, is one thing. How many "friends that are good with electronics" are going to that though.....
The obvious thing here is why would you do it......If it was acceptable and would have no effects on the woofer (it does effect the woofers peformance/spec) manufactures would pump out dvc's all day long.....
skatrcj-"I do understand that you cant get a 4ohm load with 2 4ohm dvc's,"
you can get a single 4 ohm mono load out of two DvC 4 ohm speakers. You could either series the woofers, then parrallel them together (8ohm/2 = 4) or you could parallel each and then seies them (yeilds 4 ohm too)
