Posts: 9,442 |
Originally posted by LoCoZ: Originally posted by bk4293: It's the OBX header I believe. The bad Pacesetter header was the shorty race header that blocked airflow. The only problem is he states that the down pipe is for a Focus or Contour, but the two downpipes are totally different since the focus exhaust goes straight back from the cat and the Contours is toward the passangers side.
Steve has done some research.
No just spend way too much time on this site!!!
Posts: 6,280 |
Originally posted by ZetecNinja: wouldn't a 4 to 1 header work better than those anyway? Seems like it would flow alot better...
That is a 4-1, is it not?
Posts: 3,195 |
If this is the one originally sold by SSautochrome, I believe it's manufactured by OBX...There is a bracket that connects the two flanges as shown in the photo for the JBA, in fact the header is almost identical. They originally auctioned these w/ a real pretty picture of a polished header, but these loose their bling real quick & would be better off painted to begin w/. $100 is too much for this particular one (if it is used)...I've also read that the ceramic coating on some of the cheaper headers is also a cause of cracking welds (causing the metal to retain heat longer). Most of the cracking on this type of shorty header is due to insufficient bracing of the collector flange & the downpipe adding pressure/vibration to this area.
Steeda has a real pretty one also...anyone know if thats the one mfr'd by JBA for them?
1999 Sportage 4x4...don't go there, it was free
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Posts: 3,465 |
Originally posted by ChattavegasSE: Originally posted by ZetecNinja: wouldn't a 4 to 1 header work better than those anyway? Seems like it would flow alot better...
sure like like a 4-1 but I kan't kount or do math thingz anewayz
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 8,143 |
noooo, I meant like...hmmm let me see if I can find a pic. Like this?
Posts: 21,653 |
I like this one the most: http://www.modernperformance.com/ford/focus_central_raceheader.jpg4-2-1, holes for EGR and o2 sensors already there,, too bad it probably won't fit without work to the downpipe,etc.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
I have a 4-1 header.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 8,143 |
i thought the one with the pic that I showed was 4 to 1 header and that other one is...whatever the hell its called. Now that I think about it, all 4 cylinder headers are 4 to 1  oh well, anyone...which design type is better?
Posts: 3,195 |
Originally posted by ZetecNinja: Now that I think about it, all 4 cylinder headers are 4 to 1
No, there's the 4 into 2 into 1, which gives the best low end torque (when compaired to the 4 into 1)
The race header 4 into 1 is what you've shown above. The one that is referred to originally in this post is called a "shorty" header & is supposed to bolt right on as the original manifold was retaining all factory emissions pieces parts...I guess it could be called a 4 into 1
....______o_o
.../_l l__\____\
Posts: 1,224 |
SVZETEC,
Who makes that header that you have pictured? I'm really interested because with those flanges, it would be easy to adapt to the Contour.
BTW, I just wonder if that O2 location would hit the AC compressor.
>>EDIT<< Nevermind, I just found it. $225 is very tempting.
http://euroticelectronics.com/hp_racing_4_2_1_ford_header_1.html
>>EDIT<<
Thanks,
Ben
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
