Posts: 149 |
As soon as I read the title of the post on the main index page, even before I clicked on it to read all the posts, I thought to myself: "This guy is a total F*!K'in idiot!"
"I'm not above the law, I'm beyond the law"
1999 CSVT Toreador Red
Magnaflow Resonator and large K&N
Posts: 3,627 |
well I dont think I am if nothing goes wrong with them. I cant wait til I get the pics up
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by path914: Maybe there's a reason Bembro has the holes cast into the disks instead of drilling the blanks
Not true at all. Cast in holes is a fable created on the internet. One that even I sadly had succumbed to for awhile.
Drilled rotors do have thier place, but your typical street car is not it at all. Drilled rotors are only of benefit when you have significantly more mass than required for thermal effects. Sport Bikes are a prime example of where drilled rotors make sense.
Drilled rotors WILL crack on a street car, especially where the rotor is the same as was originally sized for the car from the factory.
I wish I had more time to do a proper treatise on drilled rotors.
Posts: 2,071 |
Is there a rough timeline as to when I expect mine to crack? After ~2,500 miles, they are no worse for the wear.
Former - 98 CSVT E0 T-Red 4/4/97 #173 of 6535
Dear Santa
Posts: 21,197 |
Try 1 good track session. That should do it.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,746 |
I don't believe you or king fu joe.
Posts: 2,676 |
They will crack when heated and cooled rapidly. HEre's a fun test, but obviosuly at your own discretion and caution:
Drive to 80mph, brake hard to a near stop without locking up brakes. Repeat 3-5 times.
Then drive and cool for a mile.
Drive to 60mph, brake hard to a near stop without locking up brakes. Repeat 3-5 times.
Then drive and cool.
Drive and brake from like 50 to 25 or something, medium pressure breaking, and go home.
If your rotors survive that, and you have to be legit about it, then obviously you should be ok. For awhile. Bedding your rotors in is the BEST test to see if they can take it. The reason we're all concerned here is that stock cross drilled rotors are usually made from thicker than stock rotors, they are precisely drilled, and the rotors have NEVER been used.
Used rotors have already heated and cooled, effectively they've been bed in with the pad. If you go and drill it up, obviously some of the metal will weaken since the rotors aren't forged, they are cast, and like the discussion ensuing down below in the 3L forum about cast vs. forged pistons, the van der waals forces or whatever that hold the cast metal together will be altered when drilling on used rotors.
For reference, my Baer rotors are 13" and are 1.25" thick, significantly larger and wider than stock ones. They are cross drilled (a mistake I won't make again), but the rotors are a large enough heat sink to take track abuse and not crack.
my .02 Suneil
Posts: 3,627 |
bawhahahahaha Naw guys I am just screwing with you. some of you are funny. I dont think anybody is this stupid to drill there own brakes. LOL I still have the stockers hahahahaha
Posts: 681 |
haha?
99 Silver CSVT
