#810360 12/02/03 03:27 AM
MLuko Offline OP
I have a 99 contour SE with the I4 with a auto tranny. whenever i step on it there is a rattle/vibrating nosice comming from my car somewhere. it seems to be in the engine copartment but i checked all of it and it looks all tight. is there something that i missed. if this happened to you can you tell me what u did. thanks.
Mark 1998 T-Red SVT -Needs more Go 1999 Light Prairie Tan, Se Zetec www.cardomain.com/id/tour4reak
#810361 12/02/03 04:29 PM
sounds liek it might be a heatshiled...check the one over the catlyitic converter.
#810362 12/02/03 04:54 PM
i dunno if it's relevant at all but my dash right under my guages rattle when i accelerate hard....
"Here's a mirror, see your stupid face!"
#810363 12/02/03 05:29 PM
CEG road warrior
CEG road warrior
I think that happens to all Contours.
#810364 12/02/03 11:19 PM
MLuko Offline OP
thank you guys ill check it tomorow. its an outside noise. i stepped on it next to my freind and i could hear it outside the car.
#810365 12/03/03 09:25 PM
O
O
i had the same noise but mine only happened when the heater was on and I pressed on the gas. And then it was only for a fraction of a second. Found out it was the drive (serpentine) belt and replaced it. All good to go now.
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003 94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons. 02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
#810366 12/08/03 02:57 AM
MLuko Offline OP
I found IT!!!! My air filter box came loose. does anyone know how to tighten it? and yes an intake is on the way soon.
#810367 12/08/03 03:35 AM
air filter box is held in by two "clips"
just push down on the box and it should snap into place
if you pull it all the way out you will see where it clips in, it is in the area of the transmission mount
#810368 12/08/03 04:12 AM
Is the hood of the car tight when latched ??? Mine needs adjusting sometimes . It will rattle at idle and at slower speeds . A big screw on each side of radiator support brace . The screw has a round rubber disk on top of it. Unscrew it to raise the screw and tighten the hood .
#810369 12/08/03 10:41 AM
probably your transmission (tourqe converter)
