Posts: 2,489 |
ahah yeah i was just thinking that...if you look down there under the seats, the vents would be blowing hot air right onto the amp...
1998 T-Red CSVT 3.0L
Posts: 951 |
Originally posted by cthomp21:
BTW, you could always suspend an amp rack from the rear deck to mount the amp to. Search the boards, lots of pics of them.
searched the board, cant find anything. help!
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Posts: 2,489 |
never done this, but after doing a rear deck sub i think i have an idea...
just build a platform out of wood or w/e you want, and mount your amp to it. then get some bolts, drill a few holes into the deck and a few into the platform, and suspend the platform from the deck (by puttingthe bolts through the rear deck and into the platform)...just make sure you have some space in between the top of the amp and the rear deck. you could use nylon locknuts at the bottom to make sure it wont come loose. does this help?
damn...now that ive written all of this, i kind of want to do this
Posts: 951 |
great idea.... but you know im a visual learner  gotta see some pics. ill try that tho
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 2,489 |
oh found some stuff, here ya go: bk4293's system (hope you dont mind):
Posts: 951 |
Originally posted by Nate S: oh found some stuff, here ya go:
very interesting.... i hope i have that much room above my giant sub box. thanks
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 1,092 |
Originally posted by brianl703: Originally posted by cthomp21: Never mount an amp like this. Amps generate heat which must be dissipated. It can't do this when upside down.
That would depend on the particular amp, wouldn't it? It is possible to design an amp with adequate cooling when it is mounted in any position. One way to do it is to add a fan. Another way is to design the amp so that convection cooling works equally well in both directions. Most amps have the heat producing components mounted in the sides (as opposed to the top or the bottom), probably for this very reason.
It would depend on the amp, but for the vast majority of them I'd never chance an inverted mount. You might have no problems during winter, but just think how hot the trunk gets during summer and then with all of the heat the amp generates being redirected right back into it.
I'd have no problems invert-mounting a Blaupunkt Class T amp. They run so cool that they have plastic housings.
I'm currently using a Lanzar rack amp suspended below the rear deck with about 2" above it for cooling. I could sense the power drop this summer when it got really hot outside.
Solution: Add another Lanzar rack amp.
1999 Ford Contour SVT #900/2760 (SOLD)
2005 Mazda 6s
2003.5 Mazdaspeed Protege
1998 Ford Ranger 4x4
Posts: 2,369 |
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Posts: 2,007 |
skrilla = MEGA whore  j/k man, very nice looking setup
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 951 |
Originally posted by skrilla187:
i need my spare, showoff! j/k hot, and i love the rims homeboy
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
