Posts: 42 |
I am getting quite eager waiting for JL to ship the damn w7's! I am planning on two 12w7's, each powered by a jbl bp1200 amp (1200w @ 2 ohms, 1 ohm stable) and some other amp to drive some hefty fronts. All in all probably in the range of 3000 watts rms. I will have to get a nice big optima battery of course  Are there any bolt in alternators for our cars that make some extra amperage?? (duratec v6)
*Rides* -1999 Ford Contour SE Sport stock ATX, best time 16.66@81mph
Pioneer HU, door speakers Pair Cadence Ultra Drive 12s Sony 1000 watt Class D amp
Kills: Rockford 12" HE2 (exploded.. blew out 3 in a row, gotta love best buy protection plan :P )
Posts: 338 |
Originally posted by Superblue: I am getting quite eager waiting for JL to ship the damn w7's! I am planning on two 12w7's, each powered by a jbl bp1200 amp (1200w @ 2 ohms, 1 ohm stable) and some other amp to drive some hefty fronts. All in all probably in the range of 3000 watts rms. I will have to get a nice big optima battery of course
Are there any bolt in alternators for our cars that make some extra amperage?? (duratec v6)Im soo glad to hear you ask about getting a new alt rather than someone asking so how many caps do it need? First you'd be surprised that stock alts would proably handle the job fine...BUT i would still at least do the first option: 1) Well for one if you dont mind being out a car a day, you can get your alternator rewound and Im sure that would perfect fro your needs. 2) But if you want on a new alternator or dont want to give up the car heres a place:http://www.mralternator.com/
Posts: 8,142 |
I'll also add that with that kind of power, you will want multiple batteries.
Posts: 1,444 |
stinger also has higher output alternator in a chrome finish
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 8,142 |
Are there any bolt in alternators for our cars that make some extra amperage?? (duratec v6)BTW, are you pretty set on getting the JL subs? There are better options out there for less money if you are interested.
Posts: 94 |
If he's not intrested, i am.
99 Tour SE Sport 24V Cabernet Red Xplod Head unit/Xplod 760W Amp/15" Rockford HE2 2 10" blue neon lights in footwells Moonroof, Spoiler, Re-wired fogs to work right, 50w Xenon Fogs 80w Hyperwhite low's from midnightmoose
Posts: 42 |
feel free to share the info for the others, but I'm totally in love with the w7's. This is gonna be a "show and shine" install and the W7's are totally badass looking as well as high performing..
Posts: 42 |
I'll also add that with that kind of power, you will want multiple batteries. where is the best place to cram a second battery in this thing?
Posts: 1,181 |
where is the best place to cram a second battery in this thing? The trunk
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 8,142 |
Well, I'll offer two alternatives, one that is pretty and one that is debatable. www.stryke.com : The HE15 has close to an inch of xmax and 3 inch point to point excursion. Plus, it has a VERY conservatively rated power handling of 1000 watts. During testing, it took well over 3000 watts and about a half an hour to change it's parameters by 10%. www.blueprintdrivers.com : If you are competing SPL, it would be very difficult to beat to BP1803s with an Earthquake D2 hooked up. It has slightly higher xmax and xmech number than the stryke HE15, and costs quite a bit less *(249.00).
