#808778 11/30/03 02:51 AM
I have a bad alternator and I am having trouble removing it. the question that i have is how to get out the top bolt? If anyone has any solutions please let me know.
-Thanks
#808779 11/30/03 03:01 AM
-Thanks
Need more info...Is this a Zetec (4cyl) or Duratec (6cyl)?
Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you RB&LB causing problems in Huntsville
#808780 11/30/03 05:17 AM
if its on a zetec than you dont take the bolt out. move it out as much as you can and just simply lift the alternator out. The bold will not come out but it will come out with the whole alternator assembly. Also make sure that you disconnect everything.
NEED AN SVT REAR BUMPER!!! pm me
#808781 11/30/03 06:37 AM
anyone know where to buy a bigger alternator on the internet? i have a 4-cylinder
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
#808782 11/30/03 12:47 PM
H
H
-Thanks
If you have a four cylinder the you have to get a jack stand and a block of wood.
You need to put that underneath the engine, then remove the engine mount of the top left side ( left meaning if your looking at it directly, not left meaning if your sitting in the car), remove that, release the tensioner, then remove the serpentine belt, then the alternator, then put it all back on in reverse order.
P.S. dont screw around to much, that is hard on the other engine mounts by not having all of them on.
#808783 11/30/03 05:44 PM
I never removed any engine mounts when I took my out to get rebuilt.
It was a real PITA to remove and reinstall though.
1996 MM Zetec, ATX 192000 kms...not dead, but I'm not fixing it White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
