Hey all,
I had a P0171 for several months and just before I was about to replace Bank 1 precat O2 sensor I found a P0174 as well. I've been searching the site and have put together a priority list for myself. My tour is due for a tune-up ( 108K) but I wanted to target the CEL codes first. Other than the CEL light, the car runs fine. I'm also not hearing a hiss indicating a vacuum leak so I don't really have anything to zero in on. So here's what I think:
1)retorque UIM bolts to upper end of spec. (8-12 N-m)
After retorquing use aersol carb. cleaner to check for failing gaskets/seals.
2)clean MAF with electrical parts cleaner. Don't use q-tip.
3)replace PCV valve, Ford part is best (IMHO) eventhough it's plastic. Replace large vacuum hose to intake (order from Ford?). Use O clamps around PCV hoses. Clamps will help insure air leaks aren't present.
4)inspect DPFE (dynamic pressure feedback EGR).
5)replace fuel filter and air filter.
6)replace spark plugs and wires.
7)replace bank 1 pre-cat O2 sensor.
8)rebuild UIM and LIM using How-to.
9)?
Thanks for any input.
yap31
