#805525 11/25/03 07:06 PM
Did a little work over the weekend.
Had the brake fluid flushed and refilled - noticed a difference in the pressure needed to stop the car. The fluid was pretty dark. Also changed all 6 plugs to the autolites and added a set of stock wires.
Also performed the do-it-yourself air induction cleaning, by pulling the vaccume lines and feeding the chemicals through the two ports. The car never died (had someone idling it about 1500-2000) but produced lots of smoke and sputtered often. Cleaned the throttle body as best as I could.
With 127K on the odo, the car's running like silk. Alot better response especially at tip-in. Definately worth the time I spent.
Regarding the FMS 9mm wires - I bought a set and put them on. Had a devil of a time trying to route these, I bought several spacers and tried to rig them where it would work. Fired it up at night and could still see some arching where I guess they we're far enough apart. CE light stayed on all the way to the dealer (where I bought the stocks) The best I could do still looked like a rat's nest. So now I have an extra set 'just in case'.
1998 E1 Silver SVT
#805526 11/25/03 08:10 PM
I just put the FMS wires back in the stock holders, no problem
1999 Blk/Tan CSVT #654 - SOLD 2003 Suzuki SV650s
#805527 11/26/03 02:29 PM
Since you did the Berryman's cleaning you did change your oil, RIGHT???
Nice to clean out the engine, but change the oil after such a cleaning. All those solvents should not be left in there for too long....
