Posts: 14 |
Anyone know of a source other than ford for a rear roll restrictor for a 96 v6 mtx? Preferably aftermarket since the stock one is lame?
Posts: 2,446 |
www.spmotorsports.com buy the svt rear mount and you wont be sorry, buy the front one as well and have the holes elongated and put in som es mount and you realty wont be sorry.
Posts: 126 |
Originally posted by FLCEGkid: www.spmotorsports.com buy the svt rear mount and you wont be sorry, buy the front one as well and have the holes elongated and put in som es mount and you realty wont be sorry.
Chris, good advise, though I did manage to pick up the rear SVT mount from my local Ford dealer for just under $40. A little less than SP MotorSports. Bill
Posts: 2,975 |
Originally posted by FLCEGkid: and have the holes elongated and put in som es mount and you realty wont be sorry.
You mean widen the holes? and put in some "es mount"? I'm needing new front and rear and didn't know you could use SVT mounts for zetec, so could ya just clarify these for me? Thanks
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 2,446 |
I dont think/know if they will work for the zetec. But on a non-svt duratec you have to elongate the mounting holes because if you dont you cant bolt it all the way up. The es mount fits right in the bushing part with no problem, its just the mounting holes that need to be adjusted.
Hope that clears it up for ya.
Posts: 2,975 |
Yes it did, but could someone post a shot of a SVT mount, used or new, like a sideshot of it. That way I can compare. Thanks again.
-Tracer LTS spoiler
-GT Grille
Posts: 21,653 |
I know the front mount will work, I believe it even works on autos. Not sure bout the rear.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 750 |
Originally posted by Cris'pus: Originally posted by FLCEGkid: and have the holes elongated and put in som es mount and you realty wont be sorry.
I tried to install an SVT front roll restrictor into my '97 Zetec MTX. It does not fit out of the box. You'd have to drive out the studs from the SVT mount (the Zetec uses bolts) and enlarge the mounting holes on the mount (they're cca. half inch mismatch both sides IIRC with the frame holes, so you have to make the round holes into slots).
Seeing how much material I would have had to remove from the mount in order to make the hole large enough, I decided not to do it, as I don't think its a good idea to weaken the mount at that spot. It'd also make the mount off-center (unless drilled perfectly), I don't know how important that is. The geometry of the mount (position of the center bolt) is also slightly different, but that's probably within tolerance.
It is certainly possible though, and prolly I'm just overcautious.
Tiv
Posts: 126 |
Originally posted by FLCEGkid: I dont think/know if they will work for the zetec. But on a non-svt duratec you have to elongate the mounting holes because if you dont you cant bolt it all the way up. The es mount fits right in the bushing part with no problem, its just the mounting holes that need to be adjusted.
The SVT rear mount is a direct replacement for the stock OEM mount on the Zetec w/MTX. This is the mount that takes the greatest abuse and subsequent "sagging" in my limited experience. I have replaced two rear mounts on 1995 Zetec's with the MTX; I used OEM SVT mounts from the dealership.
Posts: 2,975 |
Originally posted by contour_r_us: I used OEM SVT mounts from the dealership.
Yeah but at 180.00 for the rear one, I will be looking for an eBay one. Or should I just call Jenkins?
-Tracer LTS spoiler
-GT Grille
