W
wanabe Offline OP
W
my friend amp makes this loud pulsating thumping noise when its on ,it dose it when the engine is on and off, but when you un plug the RCAs it stops ,does any one know what may cause this. thanks smile
I can read your mind , and you should be ashamed of yourself:p
Have you tried a new set of interconnects?
1998 Contour SVT
H&R, Koni's, 17" Team Dynamics DTM
Upgraded Stereo System
My 98\' SVT
My sub had an intermittent thump, thump, thump that turned out to be interference from my Motorola cell phone. Sounds dumb, but as soon as I turned it off, the problem cleared up.
Likely not your problem but shows how small a gremlin can be.
Cheers
99 SVT #2602/2760
Silver Frost
Some days you're the bug. Other days you're the windshield
BP Offline
you should check your ground wire. also something is possibly crossed or tangled in the rca line or speaker wire somewhere. make sure all your wires are shielded.
-Brian-
98 SE DTec MTX
well its either your ground wire or your internal ground on the amp is shot....but its the ground....check that out ...
Moderated by  dnewma04_dup1
