Installed Pressure (N @ Spec. length)
Intake
228N@39.99mm (51lbs@1.57in)
Exhaust
Service Limit 10% Pressure loss @ 30.09
Out of Square Limit 1%
Rocker Arm Ratio 1.8:1
Hydraulic Valve Tappet ******
Diameter (Std) 16-15.988mm (0.6290-0.6294in)
Clearance to Bore 0.018-0.069mm (0.0007-0.0027in)
Service Limit 0.016mm (0.0006in)
Hydraulic Leakdown Rate 5-25 seconds
The standard mondeo/duratec heads come with a hydraulic tappet.
You can upgrade to full rollerized assemblies for more rpms/less friction
As for cam selection I can definatly help you out with that. This is my speciality but I need to know where you want the power, whether your 3.0 or 2.5 auto or manaul and all the bolt ons that you have. What intake assembly your using. What heads and with what mods. What exhaust upgrades, and what final drive ratio. What your future plans are also. These are drop in. When the cams come out and get shipped i will have a set and ill have my set before anyone has theirs. So there will be a how to on the drop in and more then likely a video.
![](/ubbthreads/images/graemlins/laugh.gif)
Just so no one goes crazy and messes up the install.
I figured the price would shake a few. But like i said the offer is open until they stop making the cams
