#80032 09/04/01 02:48 AM
SVTJOE Offline OP
Ok guys. I have a system ready to go in my SVT. I have. Boston Rally Components (5 1/4) for front. I have Boston rear 5x7s. I have a sony Mobile ES AMP (XM1004GX...I think ). I also have two Jbl 10's (temproray till my Orions show up) I have a JBL 4 channel amp that is going to run these two subs. I have an alpine CDM7854 deck... I have a monster 4 gauge kit and a distribution block and everything else... But NOW the hunt is one fo a "amp jumper"? I need to bypass the factory amp. I have gon to Best buys. Curcit Citys and some other shops and ther there like " I dont have it" Where do I get this thing? What is it called exactly... Everyone says that my factory speakers will sound really bad if its not bypassed. My friend and I installed my deck and bought a premium harness for behind the deck...Did that disable it??
Thanks guys....Car audio is not my thing.
Joe
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
V
V
not sure about the amp bypass but I would like to know, why are you going to use a 4 channel amp to run 2 subs. Your better off buying a good two channel amp and if it's not that powerful you can bridge it to one channel, if the amp is 2 ohm stable. Most likely by doing this you will also draw much less current from your alternator, which is very important.
vinny "2000 T-RED SVT"
Mods:
kkm
sho shop off road y-pipe
Audio:
Alpine CDM 7874
Audio Control 4.1 EQ/Line driver
Mb quart rsb 215 comp.
Mb quart rsc 216 comp.
blueprint 1001 sub
2 Phoenix Gold qx2180 amps
no it didn't disable it. what u have to do is go behind the glove dept. and then "rig" the wires so that it bypasses the amp. it's not that hard, just time consuming and frustrating trying to figure out the right wires. but beyond that, it's not too difficult.
or if you're going to install of the components that u have mentioned, then just forget about the stupid factory amp. just disconnect it if it makes u feel better. use a deck that has 3 preamp rca connections. 1 for subs, 1 for fronts, 1 for rears. use these to power all of your speakers. that should take care of it. good luck...
Spec 23
99 SVT
No Mods (can't afford to void the extended warranty)
Originally posted by SVTJOE1:
Hey Guys.. Has anyone ever heard of Orion Cobalt subs? I can get them brand new from Orion for about $19 for the 10"s and abuot $23 for the 12"s I work for an Orion dealer. I just checked and I cant get people these deals.. I was checking today and I guess its only an employee thing. I was thinking of getting the Cobalts or mabey going to the HCCA's by orion. I can get the 10" HCCA for about 76 bucks....I really want something thats clear and hits quick..But I also want something to draw some attention when needed laugh..You guys ever hear of these subs?
Thanks,
Joe
Joe
I'm not tryin to flame you here, but you said you worked at a car audio shop? All you need is a Ford Premiun Sound harness from Metra. If you are running new speaker wires to every speaker then you actually wont need it since you have amplifiers for every channel and RCA outputs on the radio (your radio wont be wired to any speakers through the factory harness this way.)
Now if you are going to use the factory speaker wire and amplify the speakers with the sony, buy the Premium sound Eliminator, grab the double ended harness out of the bag and cut the wires in the middle (make one harness now two peices). You only need one half (forget which, think the female end) Connect the speaker wires from the sony to the right harness end (check F/R L/R to make sure you wire that correct) and plug it back into the the factory amp's output harness that you just unplugged from the factory amp
If Best Buy or CC or the shop you work at doesnt have this harness somethings very wrong. I would not buy it at CC or Best Buy though, most likely $30 :rolleyes:
APT Offline
Or call 1-888-955-6000, 8 AM to midnight Eastern to order the Ford factory amp bypass for 95-00 Contours/Mystiques.
SVTJOE Offline OP
Nah, I never said I worked at a car audio shop..But I work for an Orion dealer. I work in a Home theater store....I want to thank you guys for helping me out... So do you think I need this amp jumper?? Or can I just wire the after market amp in before the factory one??
Thanks,
Joe
ps. this is all going in tommorow!
laugh
1998.5 T-RED SVT
Sorry, my bad, didnt think Orion had home audio products. You'll need the adapter if you plan on using the factory speaker wires, so if you arent planning on routing wires through your doors then yes you'll need the harness.
SVTJOE Offline OP
Thanks KNU! hey if anyone has that part number for that bypass that would be great. I am having a tough time finding it. And I need to have it by tommorow.. Thanks alot
JOe
1998.5 T-RED SVT
Where do you work?
SVTJOE Offline OP
I work at The Home Theater in Novi Michigan. We carry lots of stuff and specialize in Sony.
Thanks,
Joe
1998.5 T-RED SVT
Moderated by  dnewma04_dup1
