Page 2 of 2 1 2
bails Offline OP
i got the vb today, it took 1 day! , it was 275, i don't know what that guy was talking about!!!!! i have another question, the electrical part of the assy, with the sylinoids (i can't spell) should i replace that? where can i get a vb to tranny gasket? thanks
You don't need to replace the solenoid if it is working fine.
You do need to pay close attention to the solenoid gaskets,
and make sure
they are put on the correct way, or else the tranny won't shift properly.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
bails Offline OP
should i replace the seal for the filter in the tranny? its the seal that you have to remove in order to get the filter out. there is nothing wrong with the one that i took out. i decided to change the filter, since i pulled the tranny, along with some other little things.
To be safe I would replace it.
Even though it looks okay, it is how many years old,
and has how many miles on it ?
bails Offline OP
where can i get the oil cooler lines from the atx to the radiator??
Try Bill Jenkins first.
If they aren't available through Bill, then you may need
to purchase 5/16" Steel line and bend them yourself.
Page 2 of 2 1 2
