my airbag light flashes 4 times in a row every now and then. i checked the problems section and i cant understand the guide. would like to know if its worth getting them removed now and getting my steering wheel or waiting
1998 Silver SVT Contour A.K.A. "The Saint" Devilish Kustoms Chester, VA
H
H
Not sure what you mean by 'now and then' but a 44 code indicates air bag monitor has detected a ground circuit problem with RH crash sensor. Visual check of mounting would be the place to start. Sensor is readily visible after raising hood; mounted on the upper rad support, just to the pass side of car centerline - a little box attached to an inverted 'L' bracket.
i was wondering what that darn wire went to...thanks
