Posts: 69 |
Guys: I did do a search, but could not find a definitive answer on this question.
Is the 2000 V6 waterpump plastic or metal? If it is plastic, has there been any failures with the new revised plastic impellar?
Sorry for another waterpump question but I need to know if I should look at doing mine down the road. I have 38K now so I have a little time.
Thanks.
'99 SVT Contour
Tropic Green
Stock
Posts: 7,117 |
You've got a 2000, so I expect you have the upgraded plastic pump installed in your car from the factory. I have the original factory installed upgrade pump in my 1999 SE V-6 with 58,000 miles on it. No hint problems thus far, the temp is holding at a very low level - even in the warmest Florida weather.
Thoughts about a replacement pump have been put on hold for now. The new plastic pump has been shown to be much more reliable than the old plastic, and the metal impeller pumps have been know to have bearing or seal failure. I'll wait it out & likely buy a new plastic impeller pump next year sometime.
Posts: 69 |
'99 SVT Contour
Tropic Green
Stock
Posts: 1,831 |
88,000 miles and still going strong...
Doug
2006 Mercury Milan V6 Premier Dark Blue Pearl
Former owner of a 2000 SVT Contour
Posts: 9,196 |
I have 47K on my 00' CSVT and haven't had any problems so far [knocking on wood right now  ] I did cbange the coolant at 30K though, even though it says to do the first change at 50K, why wait  I remember reading about the w/p on the M3's having the same problem and one thing thats said to help those cars is to keep the coolant fresh because it removes any acid build up in the coolant, somethig to think about  Also I added a bottle of waterwetter at 6K and again at 30K after I had the system flushed. I believe in that stuff completely as my CSVT runs cooler than any other I've driven or checked out!
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Webmaster
Webmaster
Posts: 1,359 |
I don't believe any waterpumps from the factory were metal.
Metal available aftermarket only.
-Lance
Lance Kinley
CEG Webmaster
95 SE, "Cassandra"
10 years!
Posts: 1,322 |
Originally posted by Lance Kinley: I don't believe any waterpumps from the factory were metal.
-Lance
That's what I understand. BTW my SVT build date May '98 had the newer (offwhite) impeller. I've never read about a problem with the newer style, only the old (black) ones.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 1,322 |
Originally posted by TourDeForce: You've got a 2000, so I expect you have the upgraded plastic pump installed in your car from the factory. I have the original factory installed upgrade pump in my 1999 SE V-6 with 58,000 miles on it. No hint problems thus far, the temp is holding at a very low level - even in the warmest Florida weather.
I don't remember seeing any posts re; metal impeller pump failures. I haven't had any problems with the two I installed. The pump on my SE has about 10K miles on it now.
Posts: 1,016 |
Waterwetter???? what's that? Where do ya get it? How much... I'm just curious.
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 9,196 |
Originally posted by epattonm: Waterwetter???? what's that? Where do ya get it? How much... I'm just curious.
They sell it most of your local autoparts stores, I get mine from Pepboys. Its basically an additive that goes into the cooling system and helps it run cooler, it really works, but you still wanna make sure the coolant is fresh, thats really the most important thing you can do, the waterwetter just makes it that much more effective. As far as price goes, expect to pay about $7.00 or so for a bottle, its kinda of a pink color, so its easy to find
"THEE" Roger R
USMondeo@aol.com
