Posts: 283 |
Ok... Now im getting very frustrated. Seeing how you are too lazy to go out and pick up the cam timing evens on 114 degree lobe centers i will RETRIEVE the information from the website for you. Here is the baby spoon open wide !!
All valve timing information derived at 1 mm or .040 inches of lift.
216 cam -4/40 40-4
224 cam 0/44 44/0
232 cam 4/48 4/48
240 cam 8/52 8/52
248 cam 12/56 12/56
Also i would like to say that no one actaully knows the stock lift of these cams. Its not 9.8 i can almost gaurantee. Those ramp rates would create more lifter wear then the big 3 would like to see. But taking what other dohc engines run at stock its usaully around .323 to .353 lift at the valve So around 8.9-8.2 mm. And the area under the curve with these cams will be much better because of the rapid valve acceleration. The increase in power will be very good through the midrange and the top really pulling through.
And i would like to know what exactly the diffrence from a 2 valve and 4 valve engine is. lift*circumfrence is the survace area for a cylinder or the flow area. The valves are there to let air fill the gap in the chamber. No magic here... The bigger the flow area the better it breaths.
Cams really lay down the same ranges of operations on every single engine 2 valve or 4 as long as the flow stays about the same.
Ex-cat cams dealer. Today we do motor mounts.. Tommorow. Intake manifolds
Posts: 1,860 |
It is 9.8. Here is the rest of the info in case you can't find it when you did your search.
ENGINE SPECIFICATIONS
General Ford DuraTech Displacement 2.5L (153CID) Number of Cylinders 6 Bore and Stroke 82.4x79.5 (3.25x3.13in) Firing order 1 - 4 - 2 - 5 - 3 - 6 Oil Pressure 138-310kPa (20-45psi) CYLINDER HEAD AND VALVE TRAIN Combustion Chamber Volume 44.5+/- 1.5cc (2.7+/-0.09in) (9.4:1) Valve Bore Diameter Valve Seats Width - intake 1.1-1.4mm (0.043-0.055in) Width - exhaust 1.4-1.7mm (0.055-0.066in) Angle 44.75 degrees Runout (T.I.R.) Max 0.04mm (0.001in) Valve Arrangements (Front to Rear) (P)rimary, (S)econdary, (E)xhaust LH Intake S-P-S-P-S-P LH Exhaust E-E-E-E-E-E RH Intake P-S-P-S-P-S RH Exhaust E-E-E-E-E-E Valve Stem to Guide Clearance Intake 0.020-0.069mm (0.0007-0.027in) Exhaust 0.045-0.094mm (0.0017-0.037in) Valve Head Diameter Intake 32mm (1.26in) Exhaust 26mm (1.02in) Gauge Diameters 31 and 24.5mm (1.22 and 0.96in) Valve Face Runout Limit 0.05mm (0.001in) Valve Face Angle 45.5 degrees Valve Stem Diameter (Std) Intake 5.975-5.995mm (0.2350-0.2358in) Exhaust 5.950-5.970mm (0.2343-0.2350in) Valve Springs Compression Pressure (N @ Spec. Length) Intake 680N@30.19mm (153lbs@1.18in) Exhaust 680N@30.19mm (153lbs@1.18in) Free Length (Approximate) Intake 46.8mm (1.84in) Exhaust 46.8mm (1.84in) Installed Pressure (N @ Spec. length) Intake 228N@39.99mm (51lbs@1.57in) Exhaust 228N@39.99mm (51lbs@1.57in) Service Limit 10% Pressure loss @ 30.09 Out of Square Limit 1% Rocker Arm Ratio 1.8:1 Hydraulic Valve Tappet Diameter (Std) 16-15.988mm (0.6290-0.6294in) Clearance to Bore 0.018-0.069mm (0.0007-0.0027in) Service Limit 0.016mm (0.0006in) Hydraulic Leakdown Rate 5-25 seconds Collapsed Valve Tappet Gap - De 0.50-1.11mm (0.019-0.043in) Hydraulic Lash Adjuster (HLA) to Cylinder Block Clearance Standard Maximum CAMSHAFT Lobe Lift Intake (Primary) 4.79mm (0.188in) Intake (Secondary) 4.79mm (0.188in) Exhaust 4.79mm (0.188in) Allowable Lobe Lift Loss 0mm (0in) Theoretical Valve Lift @ Zero Lash Intake (Primary) 9.80mm (0.388in) Intake (Secondary) 9.80mm (0.388in) Exhaust 9.80mm (0.388in) End Play Standard 0.025-0.165mm (0.001-0.0064in) Service Limit 0.190mm (0.00748in) Journal to Bearing Clearance Standard 0.025-0.076mm (0.001-0.0029in) Service Limit 0.121mm (0.047in) No. 1 and 5 No. 2, 3, and 4 Journal Diameter (all) 26.962-26.936mm (1.061-1.060in) RH Cylinder Head Intake - No. 1 Exhaust - No. 1 No. 2, 3, and 4 (Intake - Exhaust) No. 5 (Intake - Exhaust) LH Cylinder Head Intake - No. 1 Exhaust - No. 1 No. 2, 3, and 4 (Intake - Exhaust) No. 5 (Intake - Exhaust) Camshaft Runout Bearing Inside Diameter (all) 27.012-26.987mm (1.063-1.062in) CYLINDER BLOCK Head Gasket Surface Flatness 0.25 / 25 x 25.050 / 150 x 150 Cylinder Bore Diameter Grade 1 82.4-82.410mm Grade 2 82.411-82.421mm Grade 3 82.420-82.430mm Surface Finish (RMS) 0.2-0.6 microns Out of Round Limit 0.015mm (.0005in) Out of Round Service Limit 0.020mm (.0007in) Taper Service Limit 0.006mm (.0002in) Main Bearing Bore Diameter 68.998-69.022mm (2.716-2.717in) Minimum 0.25mm (0.010in) Undersize Standard CRANKSHAFT Main Bearing Journal Diameter Out of Round Limit Taper Limit Journal Runout Limit Standard Diameter 62.968-62.992mm (2.467-2.479in) Minimum Diameter 0.25mm (0.010in) Oversize Thrust Bearing Journal Crankshaft End Play Standard 0.110-0.232mm (.004-.009in) Maximum Connecting Rod Journal Diameter 49.970-49.990mm (1.967-1.968in) Out of Round Limit 0.050mm Max (0.001in) Taper Limit Main Journal Oil Clearance Standard Maximum Available Undersize Bearing Connecting Rod Bearings Clearance to Crankshaft 0.028-0.066mm (0.001-0.0025in) Maximum Thrust Bearing Thickness Standard .25mm (0.010in) Oversize .50mm (0.020in) Oversize Bearing Wall Thickness (Std) 1.503mm (.059in) Main Bearings Clearance to Crankshaft -Desired 0.025-0.045mm (0.0009-0.0001in) Clearance to Crankshaft -Allowab 0.025-0.050mm (0.0009-0.0019in) Maximum Available Undersize Bearing Wall Thickness Grade 1 2.501mm (0.0984in) Grade 2 2.505mm (0.0986in) Grade 3 2.510mm (0.0988in) CONNECTING ROD Piston Pin Bore Diameter 21.017-21.032mm (0.827-0.828in) Crankshaft Bearing Bore Diamete 53.015-53.035mm (2.0872-2.0879in) Length (Center to Center) 138.06-138.4mm (5.435-5.448in) Alignment (Bore to Bore Max Difference) Twist 0.050mm per 25 (0.0019 per 0.984in) Band 0.038mm per 25 (0.0014 per 0.984in) Side Clearance (Assembled to Crank) Standard 0.100-0.30mm (0.0039-0.0118in) Service Limit 0.35mm Max (0.0137in) PISTONS Diameter Coded Grade 1 82.390-82.410mm (3.2436-3.2444in) Coded Grade 2 82.398-82.422mm (3.2440-3.2449in) Coded Grade 3 82.410-82.430mm (3.2444-3.2452in) Piston to Bore Clearance Standard 0.012-0.022mm (0.0005-0.0009in) Maximum Pin Bore Diameter 21.008-21.012mm (0.8270-0.8272in) Ring Groove Width Compression (Top) 1.230-1.245mm (0.0484-0.0490in) Compression (Bottom) 1.530-1.545mm (0.0602-0.0608in) Oil Ring 3.030-3.055mm (0.1192-0.1200in) Piston Pin Length 55.05-55.47mm (0.0001-0.0078in) Diameter 21.011-21.013mm (0.0013in) Pin to Piston Clearance -0.005 to +0.001mm (0.0001-0.00003in) Pin to Rod Clearance Standard 0.004-0.020mm (0.0001-0.0007in) Service Limit 0.035mm (0.0013in) Piston Ring Width (Compressed) Side Clearance Compression (Top) 0.040-0.075mm (0.0015-0.0029in) Compression (Bottom) 0.040-0.085mm (0.0015-0.0033in) Oil Ring Snug Fit Service Limit 0.10mm (0.0039in) Piston Ring Gap Compression (Top) - gauge di 0.100-0.250mm (0.0039-0.0098in) Compression (Bottom) - gauge 0.27-0.42mm (0.0106-0.0165in) Oil Ring (Steel Rail) gauge 0.15-0.65mm (0.0059-0.0255in) Compression (Top) - Service Limit 0.50mm Max (0.0196in) Compression (Bottom) -SvcLim 0.65mm Max (0.0255in) Oil Ring (Steel Rail) - SvcLim 0.90mm Max (0.0354in) LUBRICATION SYSTEM Oil Pump Type Oil Rotor to Oil Pump Housing Clearance Rotor Tooth Tip Clearance Oil Capacity Total (Dry engine) 5.5L (5.8qt) Refill (With Filter) Refill (Less Filter)
2001 Lincoln LS8
1994 Lexus GS300
Posts: 4,970 |
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 283 |
oooo Real information.. thanks man much appreciated
Posts: 344 |
Originally posted by Keyser: Piston to Bore Clearance Standard 0.012-0.022mm (0.0005-0.0009in)
Keyser,good info to post. I hope a lot of people copy this stuff. Maybe Lance could put it in a help section.
One note: The above clearance should be -0.012 to +0.022mm. Yes, that's negative clearance, as in interference. This clearance spec is only valid when measuring the piston with the coating. The target coating is about 0.010mm per side. Now, when we talk about standard pistons at the factory being Grade 1, Grade 2, or Grade 3, that measuring is done before the coating is applied at the supplier. Mahle in this case. The factory is actually building to a clearance of about 0.018-0.042mm ignoring coating. (Yes, I know it's not exactly 0.020mm larger but that's what they build several thousand engines to everyday)
The clearance with coating is really for reference but once the coating is applied, you can't truly measure the piston diameter. It can still be useful and sometimes it's all you've got.
Posts: 347 |
Originally posted by Swazo: Wow! *Copy, paste*
Yup, I'm with you on that.
1996 Mondeo 24v 4-door
twin janspeed stainless pipe
cat by-pass
Phase 2 RS bodykit
16" cosworth alloys
K&N RU3530
SVT TB/UIM/LIM
poly bushings
konis/bat springs/bar
Pioneer
MSDS
Indiglos
P&P heads
2005 Mondeo Zetec Tdci
Posts: 280 |
So does anyone know how much these cams cost and what else you would need to do to your engine? I Know there are different cams listed on their site... but I did not see any pricing. Also what kind of power increases are we looking at for the various set ups? I am not technical enough to understand the extremely enlightening discussion that is happening above... so does anyone have a translation button I can hit??  Fern
1999 SVT Contour Silver Frost
Bassani,Ground Controls Street..17x7 Rage 5.0/Falken Azenis Sport 225/45/ZR17 Track...Kosei K-1 17x7.5 Avon Tech Ra 225/45/17/ Quaife/ SPEC Stage III/ Fidanza /Capaldi Racing 4.5 final drive/TCE Brake Kit 13"
Posts: 1,101 |
Hey Fernando.....just call up Johnston Research & Perf in Mississauga. They are a distrubtor. I am also interested in these cams, but they would have to wait until summer 05 when ESP is up and I have been out in the workforce for a bit (...mmm...3.0L pnp heads + valves, cams and 7500 redline).
PS....my rotors were a casulty at Shannonville too! I may also have thought of a possible cause to you failure at the track so PM me if you want to hear about it.
Posts: 283 |
The smallest cam is what most would call a street replacement cam. Good for mild turbocharging/blower. Its going to come up with power almost everywhere over stock. looking at around 10-15 percent at the top of the tach if youv got the major restrictions out of the way 10 for a straight cam swap on a stock engine id say.
The second would be a more aggresive blower turbo cam good increases loosing some of that 1000-1700 rpm torque for a trade of about 14-17 percent on top depending on bolt ons
Third is a nice N/A streetable cam or a very aggresive turbo grind (youll get too much blow through with a High Psi blower I think) youll see alot more in the mid range (3000-5000) and an explosive 5000 to the red. Looking at 20-25 percent depending on how good it breaths.
4rth is a higher rpm N/A cam capable of making power well after you hit the fuel cut. Looking at upto 30 percent down at the redline if you have your system ready to go.
The 5th cam is better left to those who have a way to really tune their car because it probably wont idle well in the sub 1000 rpm area. Makes great power above 5000 but starts to slow down on the midrange compared to the stage 4 because of the long durations. 35-40 percent as tuned length headers really come into play with a higher overlap cam.
Posts: 280 |
Thx for the info Travis. Overall I gotta say that this has been a very informative thread. Some very seeeettt info above.
Evan my brake problem was only a symptom of many other items that broke causing my left front wheel to wobble which caused the caliper braket to get cooked becasue it would constantly rub on the rotor all the way around the track. I had to replace the left front driveshaft, left front wheel bearings, left front wheel hub? etc. There was extensive damage which ithnk was caused by my spin out in the rain on the slicks.
Thx
Fern
Sorry for the hijack!
