2394002
INTAKE EXHAUST
clearance [cl] 0.00mm 0.00mm
duration [0.1mm+cl] 257° 257°
duration [1.0mm+cl] 216° 216°
valve lift [cl=0] 10.20mm 10.20mm REQUIRED PARTS
cam lift 5.00mm 5.00mm
peak angle 112° 112° followers: O.E.M.
timing [1.0mm+cl] -4/40° 40/-4° retainers: O.E.M.
lift at TDC [cl=0] 0.70mm 0.70mm
And what do you think that is... just because the cam is not dual pattern doesnt mean anything. Most v8`s run single pattern cams.. Call a 454 peaky all you want..
Im really getting sick of some peoples attitudes in this place. With this whole my opinion is correct and your doesnt matter. Why dont people open there ears and try to help others instead of being so destructive...
![](/ubbthreads/images/graemlins/nonono.gif)
We are here to help each other after all... right?
