Posts: 66 |
just curious, why bypass the amp, im installing a alpine 7875 head unit, should i also bypass the amp? i have a pioneer head now & just installed Blapunkt 4 way 6x8's in all the doors but im not to pleased with the sound. please help
1998.5 silver frost svt resonator removed, Alpine 7875 h.u. (sweet), 4 Blaupunkt 4 way 6x8's clear sidemarkers,
Posts: 94 |
The factory amp is well worth it if you are in the market for paperweights, otherwise, pull it out, it's located behind the glove box and is very simple to remove, you can buy a bypass kit or just make your own harness, you will get much better sound without it.
99 Tour SE Sport 24V Cabernet Red Xplod Head unit/Xplod 760W Amp/15" Rockford HE2 2 10" blue neon lights in footwells Moonroof, Spoiler, Re-wired fogs to work right, 50w Xenon Fogs 80w Hyperwhite low's from midnightmoose
Posts: 4,585 |
First, it accepts high level inputs that are often more noisy than low level. Second, the stock external amp can only handle so many volts input. Any more, and all the amp can do is produce distortion. So, it's a lose, lose situation. If you don't believe us, hook it up with the amp first, then without. You will notice a difference.
Posts: 755 |
plus u can't use a head unit with an amp along with another amp, namely the factory amp. they will probably blow each other up. good luck, just resauder all the wires to bypass the amp.
Spec 23
99 SVT No Mods (can't afford to void the extended warranty)
Posts: 261 |
Here's another reason... - Factory amp = about 50 watts peak power per channel
Alpine deck = 60 watts per channel.
BTW: Good choice on decks. You'll be very pleased with it. I have the 7876 and it rocks my world (don't tell my wife  ).
Black '99 Contour SVT. Stereo Upgrades & Cosmetic Enhancements ...Always clean, Always mean.
Posts: 208 |
I have the amp bypass harness from Crutchfield. However, when I got my stereo installed, I did not have the harness installed. They stated that whenever they do a system where there's a factory amp, they use it. It seems to sounds fine. I have a Sony CDX-M620. I've heard the amps in Sony HU's aren't especially good and that's part of the reason for using the factory amp. Will I truly get better sound by bypassing it?
1st Car: '78 Buick LeSabre - Da Boat 2nd Car: '93 Jeep Cherokee Sport - Bebe aka BlackBox Current Car: '00 SVT Contour - CJ aka Connie Jay
Posts: 4,585 |
I have an older Sony HU that I took from a previous car. It sounded good in that car (now I'm not using it for power).
It sounds like your installer was lazy. it may sound fine, but if you have no comparison, the HU alone will sound even better.
