I just replaced the battery on my 98 V6 2.5L DOHC and the battery came with a vent on top, between the posts and an adapter and hose if needed. I then noticed that there is a hose that is clamped onto the battery hold down bar near where the vent on the battery is located. This hose is not attached to anything on this end and only extends about one inch past the attachment point and then it turns 90 degrees down for about an inch.
Is this hose supposed to connect to the battery vent or what is this hose for?
Does anyone else see this hose on their vehicle and is it attached to anything by the battery?
The other end is attached to a metal case that appears may be part of the crankcase but I am not sure.
Thanks
