Posts: 912 |
I am not to worried about the car. It is done anyways, motor is siezed and the atx tranny is on the fritz.
Its more on how much green I am ok with losing.
Jason
00 Audi S4, 2.7 Bi-turbo quattro
01 S10 Xtreme, 4.3l
98' Contour SE with some mods
96 Cavalier (beater)
Posts: 912 |
Cost wise: core motor, build it up ( basic headers, cam, mild porting (or new heads if i can afford it), bigger cam, new intake, etc ); buy a clutch, bellhousing, tranny, shifter, clutch linkage, headers, exhaust, driveshaft, and rear; fabricate and weld-in a new rear suspension, motormounts, a new firewall, and a new trans/driveshaft tunnel.
Thats what I am looking at.
Jason
01 S10 Xtreme, 4.3l
Posts: 1,360 |
Originally posted by LoudnQuik: Cost wise: core motor, build it up ( basic headers, cam, mild porting (or new heads if i can afford it), bigger cam, new intake, etc ); buy a clutch, bellhousing, tranny, shifter, clutch linkage, headers, exhaust, driveshaft, and rear; fabricate and weld-in a new rear suspension, motormounts, a new firewall, and a new trans/driveshaft tunnel.
5-6K for parts huh? not to bad...*zippy shoots hole in checkbook*
Posts: 208 |
I think it can be done, but I do think you would want to reinforce the chassis quite a bit, our cars are a bit on the flimsey side as is, and there is not a lot of structural support on the rear section of the car. Good luck!
00 SVT Contour: SHM LT headers, LSD, Spec Stg 3...dyno:190.3whp sold 02/04
04 Subaru Baja Turbo 5-spd
00 Camaro SS 393cid: 510rwhp/469rwtq, 11.16 @ 124.95(hit 1-2 limiter)
www.erikz.org
Posts: 1,360 |
of course it can be done. there are 2 things required before you can accomplish the impossible: Money and Knowledge. once you have those, you can do anything. if you are in uncharted territory (as this would be) then use your money to buy more knowledge
Posts: 8,143 |
one question...what the hell do you do to be able to afford this?
Posts: 912 |
I am a executive programmer for microsoft.
lol yea now these numbers have been put out after the fact, I originally went into considering this when I thought it would be 3 to 4 thousand max. But now it is not looking that way and I am considering going with that Protege 5. Realistic, its looking to upwards of 8k perhaps more.
For something that MIGHT work!
Jason
01 S10 Xtreme, 4.3l
Posts: 912 |
Oh and to make it clear for any of you who took me seriously on that microsoft answer, I was kidding!
Jason
01 S10 Xtreme, 4.3l
Posts: 3,627 |
I started to say... what the F**K you driven a contour for?
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 9,196 |
Why not contact the people who made the kit for the V8 RWD Focus conversion, maybe they'll have some ideas for you
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
