Posts: 391 |
or you could readjust the belt tensioner, which would fix the problem alltogether, because what happened is the belt streched itself out, because ford for some reason decided not to give us an automatic tensioner .
Alan
93 Acura Integra LS 5spd
Horizon Gray Metallic
-96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm
Champagne Metallic CC
Pics
Posts: 21 |
Shimmed the timing belt cover last night and all is fine. While I had the cover off I inspected the belt, which appeared to be in excellant shape, and exhibited proper tension.
'95 Contour LX 54K miles
'00 Giant NRS XTC1
First new car 1964 GTO
Posts: 1,459 |
Originally posted by RussL: Shimmed the timing belt cover last night and all is fine. While I had the cover off I inspected the belt, which appeared to be in excellant shape, and exhibited proper tension.
Glad it worked for you. You may still notice a little noise when it gets really cold this winter. I think I read somewhere that the cover on the later model zetecs was redesigned to provide a little more clearance. ----------------------------------------------------- First new car 1964 GTO (I'm a lot older than you guys) ------------------------------------------------------
My first car was a 57 chevy.....but it wasn't new. I got it in 1967 from a police auction. It had been confiscated for running moonshine. It had a 283 V-8, but it wouldn't hold a candle to these zetecs.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 2,975 |
Originally posted by Obsidian: just take the cover off. It's two 8mm bolts and its cake to remove
Yes for a pre98. My 98+ cover broke and still wouldn't come off then.
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 328 |
Didn't I read somewhere that the tensioner is plastic and sometimes breaks causing the belt problem? By the way... Originally posted by bentleywarren: ----------------------------------------------------- First new car 1964 GTO (I'm a lot older than you guys) ------------------------------------------------------
You're not a lot older than all of us...my first new car was a 1971 Fiat 850 Spider convertible.
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
Posts: 569 |
Back when I first bought my car I had a sound comming from the timming belt. I removed the belt to find that the belt was riding on the edge of the pully. Took it to Ford and they found the tinsionor to be desentagrating(sp) so they replaced it and been good ever since.
....Brad
Your mom thinks I'm hot!! But my wife rocks!!
99 Mestique Zetec ATX, 96 4Runner 5speed
Mods? Um gotem.
VFA-94VFA-122 VFA-115
Posts: 1,360 |
please tell me you have replaced that belt? those chunks missing are usually a good sign of needing a new one...
Posts: 2,975 |
I'm on that boat, Mine is getting hairline cracks and why is my intake cam gear shaking when turning?
-Tracer LTS spoiler
-GT Grille
Posts: 1,360 |
ummmm i didnt hear you say that...do de do de do. anyway, try tightening the gear. is your belt loose? if so, tighten the tensioner.
Posts: 288 |
I took the top cover off the other night and ran the car for a few minutes till it warmed up. Funny thing is that it seems the belt is hitting the bottom part of the belt cover too. Also the belt isn't exactly ligned up straight on the gears. What i mean is it isn't in the center forming a nice parellel line with the engine. It's closer to the center on the back gear and on the edge of the front. Thats a bad thing right?
Hey does $32 sound about right for a timing belt? Thats what they quoted me at kragen. And $72 for a O2 sensor.
-Rob
White 95 GL ATX
56K Miles on it.
Optilux By Hella Fog lights (The Angel Eyes)
Driven hard, Just like I like it!
