#791455 11/08/03 01:17 PM
I have a 95 Contour V6 , auto and i am hearing this weird vibration when I am driving. Its like somthing is rubbing but I only hear it when the car goes over bumps. I jacked up the car on the drivers side and I noticed that the trans is resting on the sub frame. Does this sound right? could the trans mount be bad and it let the trans dro-p on the subframe? Can someone with an auto check this out on the car and let me know??
Thanks,
Pete
#791456 11/08/03 02:08 PM
You're right - the transmission mount is gone. I had the same problem. The transmission should not be resting on the sub frame. You may find that all four mounts are bad, rather than just one, but the mount that connects the trans to the driver's side fender is almost certainly gone.
#791457 11/10/03 06:31 PM
Can anyone else shed some light on this problem?
