Page 1 of 3 1 2 3
#78865 08/03/01 04:10 PM
Do you have a box design program or something?
As my suspended under the deck box won't work, I'm going to build a vertical band-pass box in the corner of the trunk with the port firing into the hole in the rear deck.
I need to figure out the chamber sizes and port length/diamater but have no idea where to find the info.
Thanks in advance,
-Colin
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
APT Offline
Thanks Aaron. What happened to the old handle?
I've been thinking of going with something a little more creative myself.
-C
1999 SVT #900/2760
Born on 1-20-99
WinISD is one of the better free software programs available. That is what I use most of the time.
APT Offline
You can't, Dave already tried ' Creative '.
It's just a poke at Honkeytonk Monkey's message: Here .
I may change it back on Monday.
Aaron
So, what sub/s are you using?
LOL, you guys are funny. Ya'll crack me up!
Dave, I'm using a pair of 8" Audiobahn DVC (4ohms each coil) subs. I'll run them in a circuit to give me a single 4ohm load to bridge to my amp. I got a pretty good deal at $31/ea.
I replaced my Free-Air Kicker with one of the Audiobahn subs just to see how it sounds. It seems that they don't like the Free-Air setup like the Kicker, tho. Bandpass, here I come.
1999 SVT #900/2760
Born on 1-20-99
I'm taking a guess that they are model number AW831X, is that right?
You are correct.
1999 SVT #900/2760
Born on 1-20-99
It looks like a bandpass using both woofers would need a 1 cu. ft. rear chamber, and a .625 cu. ft. front chamber. The front chamber would need a port 3" round by 6.4" long. This would be the ideal box, but you could get away with a .75 cu ft rear chamber fully stuffed. This set up should give you ~5-6db more output from 50-85 hz, than your infinite baffle setup. It rolls off pretty sharply under 50 hz. With cabin gain, you should have usable response into the mid to low 30 hz range.
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
